SOURCE: how to adjust sling/ wear sling?
Sorry ... here's the web site:
http://www.askdrsears.com/html/5/T051120.asp
Hope this helps.
SOURCE: sciphone I68, service provider ATT, GPRS not subscribed
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Just be Patient and make sure you double check everything you put it it has to be exactly as it says.. I just set mines up yesterday and it works fine.. Hope this helps! It took me forever to find the solution hah
SOURCE: i cant figure out how to attach a sling to a
Yankees, to get the correct cap you need to know if it has a spring loaded ball detent on the barrel loop that indexes against the cap. If so... here's the kit you need.
http://www.brownells.com/.aspx/sid=43908/sku/ER_Rem__870__20_ga_
As for the **** stock: You'll be well advised when I tell you to take it to a gunsmith and have it drilled properly. It is very difficult to drill this hole for the sling swivel stud correctly, When I do these I mount the receiver and **** stock in my mill vise to get it perfectly centered and use a specialty stepped drill bit.
Hope this helps, Mark the Gunsmith
SOURCE: Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system
info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that
says IR and indicates the channel to which remote control 1 is
configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1.
While displaying the system info page, press and hold the SAT button on
your dish network remote until all other modes are flashing, about 3
seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure
you enter the corresponding IR code into your slingbox remote control per
the instructions in the Slingbox documentation.
SOURCE: "Media File Not Found", for my Sony Ericsson w580i
Please call the service provider to fix this problem.....
So Larry. Why not? Netflix and amazon stream just fine. What is the difrence? Why just a shirt no?
Yes you can!!! 3.0 megabits sec constant cone toon and app. I have it working Lary!
