You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
SOURCE: 1992 Isuzu Rodeo Distributor wires
On the 3.2L distriburorless ignition, the firing order is a straight 1-2-3-4-5-6.
Cylinder numbering .
Hope this works for you
SOURCE: 1992 Isuzu Rodeo Distributor wires 3.1L engine
Isuzu seem to have complicated things by changing engines, firing orders and even direction of rotation! As you can see, they've numbered the cylinders the other way than the 3.2L.
The Firing sequence for the 3.1 (traditional distributor) 6 cylinder is as follows -
If you take the distributor cap off, there should be a "No.1" formed on the inside. Stick a lead on this before you put the cap back on and go from there.
As leads are different lengths, you may have to swap a few to find the best fit.
I think 2 of them will look out of place - but that's the way it's designed. Just make use of clips for holding them neatly.
Thanks for using Fixya.
SOURCE: Isuzu Rodeo w/3.1L engine
Front Passenger side on cap is 1 - if you look on the inside of your cap there SHOULD be a pin marked with a 1, and the plugs go CLOCKWISE not counter. Just had the same problem myself with my 91 Rodeo. Cylinders are as follows Passenger side (front to back) 1 - 3 - 5, Driver side (front to back) 2 - 4 - 6. I called the Isuzu dealer and they told me it was counter clockwise, but when I hooked it up that way it backfired through the Carb.
SOURCE: 1997 Isuzu Rodeo
on the side of the block on the passenger side....u can see it through the wheel well
SOURCE: Crank Sensor in 94 Isuzu Rodeo
it's on the bottom of the motor, towards the back on the passenger side. It has a small clip of wires and one screw holding it on. You may want to pull it up on ramps- if it'll run- otherwise, get under the Rodeo, it's up a little higher than the oil pan, and to the passenger side. (it's right on top of the two lines that run to the bottom of the radiator.) You will need a 10mm socket to remove it. I have added a few pics showing the location (i just completed this task myself)
