Question about KLH Audio Players & Recorders
How much is a KLH SW-90 subwoofer worth in good shape
    Top Expert:
  • KLH Master
  • 52,782 Answers
Fixya does not do appraisals.
Posted on Mar 17, 2018
SOURCE:
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
smarthome2
  • 1114 Answers
SOURCE: Hey, I've got a KLH sw-12 powered subwoofer. Few
Pull the amp out of the cabonet and check the fuse first. Then look for visible brown marks on any of the electronics, which will at least point you in the right direction. If you can solder, you can fix it. Hope this helps. If you need further help, post a comment and I can help you troubleshoot more in depth.
Posted on Sep 26, 2009
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
Moe66
  • 13 Answers
SOURCE: I have a KLH SW-90
I have the same amp. there a two ways to use it: The phono plug inputs are low level, are for use as an amplifier only, and their only output is the subwoofer output. In this case, any stereo satellite speakers would be driven directly from your stereo amp.
The high level inputs are meant to be driven as the same as speakers from your stereo amp. A circuit inside samples the bass and directs it to the sub amp and output. this same circut passes unamplified outputs to the satellite outputs. PM me at moestevens@cox.net if you need further info.
Posted on Jan 06, 2011
SOURCE: my model 765S KLH powered subwoofer keeps blowing
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Posted on Jan 09, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Lightning hit the speaker and now it makes a loud buzzing noise. The fuse looks good, but not sure if it is.
It's very likely that lightning has damaged the internal parts of the speaker. You may be able to get it fixed, but it may cost more than the sub is worth.
Oct 19, 2015 | KLH ASW10-120 Subwoofer
I have this reciever and it has alot of static, is it worth fixing as don't know the price . it was given to us. is it worth the money
Static is good - that means the receiver is working. You just need a good antenna to get the radio stations better. It should work with a CD player - connect one hear what that sounds. If it's good, then the amplifier is in good shape.
Jan 08, 2011 | KLH R5100 Receiver
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
Nov 13, 2010 | KLH ASW10-120 Subwoofer
I have a KLH SW-90 amp. When I plug in the RCA plugs I don't get any sound to the Satelight speakers. Is this a sub amp? Do I need to hook up the high input wires to make the satelight speakers work?
Oct 24, 2010 | KLH Audio Players & Recorders
Dec 26, 2009 | KLH ASW10-120 Subwoofer
My speaker just rip.. i like to know any subwoofer is ok for replace??
it's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
Dec 12, 2009 | KLH ASW10-120 Subwoofer
Info
I wrote to KLH and they sent me the schematics for the upper and lower boards. I asked if I could share them, and they gave me permission to post them for use here.
Have fun!
KLH ASW 10-120 subwoofer schematic - lower board
KLH ASW 10-120 subwoofer schematic - upper board
Mar 10, 2008 | KLH ASW10-120 Subwoofer
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
