Question about Toshiba 36A43 36" TV
Cannot turn channels, or volume. Menu keeps popping up, at short intervals it states, This programs exceeds limits, hit mute to key pin, then goes back to program.
I had the same problem.U will have to change the micro chip(the one with a metal shield on the top).Hope it will work.
Posted on Dec 31, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
My at&t pantech burst keeps restarting. how can i get it to turn on and not restart?
You have to reset your whole phone. Hold the power button and the volume button down at the same time until Pantech pops up on the screen and when it does let go of the power button but keep holding the down volume button down. When the triangle pops up let go of the volume button and press the menu button. Use the volume button to scroll down to wipe data. Hit the home key.. scroll down again to yes and hit the home key. Hit the home key again on reboot system. That's it ! :)
Oct 20, 2012 | Cell Phones
Where do I go to start/turn on my webcam in my acer aspire 5517?
Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
9. It appears that magnifier is turned on the computer. Please follow the steps mentioned below:
Click Start> Control Panel> Ease of Access> Ease of Access Center> Make the computer easier to see> Uncheck "Turn on Magnifier"
10. Reset BIOS Password: If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire 5610-4648 Notebook
How to activate Web Camera ie Crystal Eye ?
To use Camera Assistant Software:
Thanks and regards,
Jitha
Nov 24, 2010 | Acer Aspire 4720 Notebook
Webcam not working
Try reinstalling the WebCam driver, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate WebCam (Suyian or Chicony) and install it and restart the computer.
If the camera is still not working then can perform a factory restore, to do so follow the below steps: Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 5315 Notebook
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Mar 12, 2009 | Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Remote sensor
the menu button on the set has a short and needs to be replaced I'm not sure which part # it is but there is only 2 styles of these buttons used in this set the part #s are
1-762-816-11 and 1-692-431-21 I would order them both, buttons on this set short (volume, channel, ect..) it's good to keep the extra on hand.
Jan 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Service Mode Telefunken TTV-29SX
volume to 0
press and hold mute on remote and menu on tv
Hope this helps
Dec 05, 2007 | Televison & Video
Toshiba 36A43 36" TV Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
