Question about Garden
SOLAR LIGHTS FOR THE WALK
BRAND NEW SET OF 10 LIGHTS. 6 WORK GREAT TWO DON'T WORK AT ALL & TWO FLICKER
  • 94 Answers
These are self contained units and all that you can do is take the ones that are not working properly back to get new ones. They should work fine out of the box and last up to 15 years!!
Posted on Aug 23, 2009
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 20, 2015 | Olympus Camedia Cameras
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
The sony model #CDP-c910 skips discs continually and does not stop to play a disc. Am interested in repairing this set or purchasing a new identical set if it is still available. The size is...
Try changing the (only) belt the player has with a brand new one. Go to www.partstore.com. I believe it costs more than $10. Clean the pulleys with isoprophyll alcohol using a cotton swab after removing the old belt.
After you remove the top cover, take a careful look how the belt is placed. Don't unscrew anything. The belt can be removed and replaced without removing any screw. A paper clip will help if you don't have the right belt removal & replacement tool. A commercial CD lens cleaner (I use Scotch brand) will greatly help. Just insert it in your magazine and run for a few seconds to a minute. This is not a sure fire solution but most of the problems in this model is attributed to an loose/overstretched old belt and a dirty laser lens. I hope this helps & good luck!
Jun 10, 2011 | Sony CDP-C910 10-Disc CD Changer
My WD- 60735 mitsubishi tv will come on and work properly for about 5-10 mins then shut its self off. A orange light will flash 1-3 times then go green and blink for a period of time, what is the prblem?
Count the number of flashes of the green light and make note if there is a sequence. Google WD-60735 blink codes. This will send you to a number of links to choose from. The blink code will tell you what is wrong with your tv.
May 08, 2011 | Mitsubishi WS-55859 55" Rear Projection...
My monitor flickers erradically.
Flickering erratically is usually a sign that the fluorescent tubes that light up the LCD are failing, or the high voltage power controller that drives the tubes is failing. Although these can be replaced at some cost and a great deal of expense, it is usually not worth it with very nice, new & larger displays selling for less than $ 150 (23" HD wide screen moitors) from even the best brands such as Samsung, Planar, LG and Viewsonic.
Jan 11, 2011 | Mgc P700 17" Flat Panel LCD Monitor
I have a lucent 18 d corded telephone system in my shop, i have tried numerous times to set current time & date. i follow all the instructions & it simply wont go into program mode. it used to work...
I'm guessing you didnt press the left hand intercom twice. Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Aug 08, 2010 | Lucent PARTNER18 Corded Phone
Solar garden lights that don't hold their charge
Actually it is the batteries that are not taking or holdimg the charge...replace the batteries with rechargable ones and they will work...
heatman101
Mar 19, 2010 | Garden
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
I would like to rewire a solar security light (motion activated) to stay on at dark. Brand westinghouse
The light will only stay on as long as the battery lasts. My guess is that will not last all night. What you can do is buy a light sensor switch (or even a light sensor socket adaptor is available to save you from having to wire it in) to keep a light on during the night. You can use a CFL or even an LED lamp to save electricity, but it is unlikely that a solar-charged cell will power even one of thes all night long.
Nov 16, 2009 | Solar Motion Security Light Conversion...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
