Question about Motorola Mobility RAZR V3i Cellular Phone
How to install software
< Boot LoaderOA.30SW Version;R479-G-08.B4.85R0k to program connect USB data cable>Sir what i can do? plz solve this problem.
2 Suggested Answers
  • 15 Answers
SOURCE: What is fix for phone to load to main screen instead of stopping immediately at screen showing 'boot loader 08.E0' and ..OK to program, connect USB data cable
it's probably the connector cable or the housing has rust. must be cleaned.
Posted on Jul 23, 2016
Testimonial: "Thanks Laurie for your interest and suggestion. Unfortunately the rusty connector cable is not the much hoped-for solution...cable is brand new and phone and computer connections (the 2 ends of cable) are both in tip top shape having been used successfully for battery charging (at phone) and for flash drive installations (at computer)....further to my description of what appears on the phone screen to start off with, and which led me to connecting a data cable between the phone and a PC, is "..phone code sig error 35:02...". His is shown just ahead of "..OK to program, connect USB data cable.." I have hunted a lot on the Internet for an explanation of this code, and although many people report this code, there is no clear discussion on what to do....Also, at one discussion for handling the elimination of the white-text-on-black screen advising about errors, there is mention of a need for "P2K Tools" and "P2K Driver 2.9", but is then mentioned to obtain these from "modmymobile.com". Searching for the latter one ends up on the Motorola website and notification that this data is not available...?? ...It would heaven-sent to find some one out there that has these items and can make them available....."
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
Apr 24, 2011 | HP Deskjet F340 All-In-One Printer
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation
> Blocked VLK
> Windows Product Key: *****-*****-3R89F-D2KXW-VPK3J
> Windows License Type: Volume
> Windows OS version: 5.1.2600.2.00010100.3.0.
Where did you obtain the CD-ROM that you used to install Windows,
using that Product Key?
A "VLK' is a "volume license key" -- when some organization purchases a specific number
of licenses to install Windows XP, Microsoft issues a "volume" license-key,
so that all (up to the number of licenses they purchased) computers in that organization
can use the _same_ license-key.
If Microsoft detects that the product-key is being used *OUTSIDE* of that specific organization,
then Microsoft will *BLOCK* all attempts to "activate" Windows that cite that product-key.
I did a Google-search for '3R89F-D2KXW-VPK3J' and Google reported 37 THOUSAND web-pages that contain that string. That is a *DEFINITE* sign that the VLK has been "leaked" onto the Internet.
So, you are trying to use a "non-genuine" copy of Microsoft Windows XP.
Thus, you are a "SOFTWARE PIRATE".
Purchase a *GENUINE* copy of Windows XP (or Vista or 7) and install it,
and throw away your "pirated" copy of Windows.
Dec 10, 2010 | Computers & Internet
I turn on my phone and it doesn't boot up. it only shows the at&t logo and "Boot loader 0.700 SW Version R272311_U_97.0 4.30R1_F Battery OK OK to Program Connect USB Data Cable
your phone is booting in flash mode.connect a usb cable to your phone and connect it to your pc,start your phone open up motorola phone tools or a p2k phone tools program .flash your phone and reload the software
Mar 31, 2010 | Motorola Mobility RAZR V3
Not connected to internet via data cable
do you have the installer for your phone? if you have, try these steps..
1. restart your pc (to make it fresh,and hereby erasing some problems created during your cable connection)
2. install the software for your phone model(make sure it is compatible to your operating system)
3. connect the usb data cable, let it install automatically first.
>>if it didn't install and resulted to the same issue,
repeat step no 1, 2 and 3, but this time, don't let install automatically,instead..
1. open your device manager
2. look for your usb data cable.
3. update driver.
4. uncheck the look for the best driver automatically
5. check the box for ''include the driver in this location''
6. browse where you installed your software, preferably it goes to c drive, program files.
7. check if it will install..
Feb 21, 2010 | Nokia 5130 Cellular Phone
I just bought a sylvania 4gb mp3 player and i installed the program on the disc and then plugged the mp3 player in and my laptop and it won't show up in my computer
The SMPK4066 not responding could be solved using next help from the manual:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4066_ENFR.PDF
If there is no picture displayed after the player is connected to PC and cannot serve as
storage disc or cannot be powered on after the battery is fully charged, please refer to the
following steps to update the software in the player.
(1) Download the most updated software from the attached CD (if any) or from the
website and implement the setup.exe files in the folder to complete the installation.
(2) Long press power button of the player for five seconds and then plug in the USB
cable.
(3) Implement the updated software installed by step (1) to start software upgrade and
release the Power/Stop button.
(4) The upgrade of software may format the player, so please copy the music or files in
the player.
(5) If the software upgrade program cannot detect the player, please unplug the USB
cable and repeat step (2) and (3) until the player is detected and the software
upgrade is completed.
There's a firmware update for the SMPK4066 available on the web:
Right click next link and select "Save target as..." for saving the zip file to a location on the computer.
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4066_FW_UPDATE.ZIP
Unzip the file and see the information steps from the manual above, how to perform the update.
Need more information ? Just post a comment.
Dec 31, 2009 | Sylvania SMPK4066 MP3 Player
Nokia 3110 C phone is having the problem.
SIr My Name is Shakeel Iam Using My Nokia 3110 classic But Iam Facing Software Problem Vit This Handset Frm Past Two Yrs Iam Not Having Calculator .....
Sir Plz Rectify My Problem Plz ....
Thanks Regards
Shakeel Ahmed
Ph.No 9703970704
May 27, 2009 | Nokia 3110 Cellular Phone
Motorola phone tools version 4.4
There is a new version of Motorola Phone Tools (v5.0.5) which when downloaded and installed will automatically update to the newest Phone Tools program. This should solve your problem.
Go to the following website:
http://motoroladownloads.webs.com
Sign up to enter the site. (It's as easy as 1-2-3)
As a member, you can then download the Motorola Phone Tools (PC Suite) for your PC for free.
**Make sure you download the USB Drivers, too.
The download for the PC Suite is in .zip format. You'll need to unzip it to a new folder. (You can create a new folder on your desktop)
After unzipping the file to the new folder, double click on it to open > locate the >>
Setup884ac5e.jpg icon and double click on it.
This will install Motorola Phone Tools (PC Suite) on your PC.
Start the Phone Tools Program by double clicking on the icon on your desktop.
Download the Data Cable/Modem drivers and attach your phone to your PC with a USB data cable.
(You may also be able to use Bluetooth)
The PC Suite will include all of your options on the left hand side. <...>
Apr 01, 2009 | Motorola Mobility ROKR E6 Smartphone
I want RAZR V3i software
no audio add in itunes software my motorola v3i plz tell me some solution
Mar 31, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I'm trying to transfer my phonebook from my old V220 to Razr V3xx
Are you using the latest version of Motorola Phone Tools v5.2.7?
As a member, you can then download the Motorola Phone Tools v5.0.5 which when installed will automatically update to v5.2.7. Using this version should solve your problem.
**Make sure you download the USB Drivers for Windows, too.
Jan 17, 2009 | Motorola Mobility RAZR V3
Motorola tools software not working with "Vista"
Did you download and install the USB Data Modem drivers, too?
Also, on your phone go to: Settings > Connection > USB > Default connection > (and make sure Data - or Internet - transfer is selected and not Memory Card?)
Motorola Mobility RAZR V3i Cellular Phone Logo
99 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
