Where do i put freon in to fill it up whirlpool 12000btu
  • James Stopp
    James Stopp May 11, 2010
    Central unit or window unit. Window uits do not have a port to add freon.
  • 25 Answers
I assume you do not have any a/c cert. so you must be looking to add R-134, to a automobile you will see a cover sometimes black sometimes blue (NEVER RED) The refrigerant will go in at the fitting under that cap but you want to be sure to put it in on the low preasure side of the compressor. this should also be done with a gauge set so not to over fill the system. over filling will also cause the compressor to shutdoun as well on over preasure situation.
Good luck
Posted on Jul 31, 2009
How do i put freon into my 12000btu haier standalone unit
These are sealed units a charging port (tap valve )would need to be added , first clean unit and verify a refrigerant shortage . Remember these units are sealed and require no added refrigerant unless there is a leak. Test for difference between air entering unit and cold air coming out and this should be 20 to 25 degrees for a clean unit ,and if you get this temperature difference no extra refrigerant is needed !
Oct 02, 2014 | Haier CPN12XH9 Portable Air Conditioner
How do i put freon in this unit
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products.
Jun 03, 2014 | Whirlpool 75-Pint Dehumidifier
Recharge a/c i have r12 which valve do iuse black or red
line that goes to compressor is low side line out of compressor is high side
always fill on low side
also r12 hase been band for sevral years and should not be used
if this freon is r-12 conpatible or replacment then your fine
after leak been repaired and system pressurized and vacumed out
start engine put a/c to max blower motor to hi open windows
conect your fill bottle to low side open valve and system will start filling
when freon reach enougt pressure the compressor should start and draw in
the freon if it fails to start you could jump the low pressure swich to help draw in
freon when system has drawned its capacity shut off your bottle and disconect your line to fill
cap off the valve
if compressor fail to start you have another issus could be electrical
take CAUTION doing repairs to a/c system
Apr 02, 2011 | 1989 Toyota Camry
Hi i replace 3 lg compressor 12000btu and i feel i did everything corrently but my compressor burnt ,and turns of the circuit breaker.i have check the voltage which is 240,current 5.6amp and psi 55...
dear sir
i think you did wrong connection with compressor please make sure first your connection is correct then install your compressor unit make vacuum in unit and then try to fill freon also use over load protectors in compressor for security .correct connection are giving you blow :
C : connect here wire which one is coming from main supply/thermostat /overload protectors
R :connect here wire which one is coming from capacitor ( C terminal).
S : connect here wire which one coming from H terminal of capacitor if capaciter/if capacitor is no mark then one wire i mean no require from H OR C terminal .
hope answer the question
thank you
please vote!
Oct 01, 2010 | Heating & Cooling
Where is the ac hose to put in freon
Its on the side of the freon holding tank, little black cap comes off, It is against the law to fill yourself due to ozone layer, only qualified tech can fill it for you.
May 20, 2010 | 1997 Oldsmobile Achieva
Where do i put freon in to fill it up 12000btu AC needs freeon i need to know where the fitting is to fill it
No access ports on window units. Need a line tap for that or call service tech. There is oly so much you can do without knowledge of air conditioning. russ
Jul 31, 2009 | Heating & Cooling
Whirlpool model EV201NZRQ, stoped freezing,lights are on, compres
in leaving the door open you may have over heated the compressor and not it is not pumping enough freon anymore
Dec 11, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
