SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: My Cuisinart 12 cup programmable coffee maker will
Hello jimmarsh,
You are right, there is a way to fix this. This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used an eyeglass screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
