Where do i put freon in to fill it up 12000btu AC needs freeon i need to know where the fitting is to fill it
  • 614 Answers
No access ports on window units. Need a line tap for that or call service tech. There is oly so much you can do without knowledge of air conditioning. russ
Posted on Jul 31, 2009
How to fill ac
take it to firestone or somewhere and have them but New Freon , or how else can I say recharge your Freeon
Jul 28, 2012 | 1993 Cadillac Eldorado
My 2001 ford focus ac light is blinking but hot air is coming out. I just had freon put in the car one can
it might need another can, with ac on and controls turned to ac max the compressor should start cycling as the freeon is added. if not you might have a low or high pressure switch that is bad check fuzes incase you blew the fuse for the ac compressor
Jul 28, 2012 | 2001 Ford Focus
When I put freeone in my 2002 chevy monte carlo it last for about two weeks, what could the problem be?
You more than likely have a small leak in your in the hose coming from your ac compressor. take it to a certified mechanic to get it checked. Hope this helps.
Bobby
Jun 29, 2011 | Chevrolet Monte Carlo Cars & Trucks
Were do i add freon to my honda accord 1992 i been looking for the place to put freon but i cant find it if anyone knows were it is please tell me
you need to charge your ac system on the low side ac line fitting. the connection will be the smaller one of the two fittings. is your system r12 or r134a?
Jul 26, 2010 | 1992 Honda Accord
Where do we put freeon for the air conditionner
There are only 2 fittings on your ac system. The low side is the one you put in refrigerant (r134a). It is the smaller sized fitting usually located on low side hose that connects to receiver dryer (looks like a can on passenger side firewall). The quick connect fitting on any recharge hose will only fit on this correct fitting. The other one (high side) is too large to fit. So you cant put it in the wrong one.
Jun 06, 2010 | 1994 Lincoln Town Car
2003 monte carlo ac clutch wont engage
your a/c freon has a low pressure devise that will not enguage the compressure you can buy 1 or 2 cans of 134 freeon and connector that well only fit on 1 of your freeon lines your a/c must have a leak in it your best bet is a repuable a/c shop good luck CJ
May 20, 2010 | 2003 Chevrolet Monte Carlo
I got freeon put in my car and a day later it leaked out. i was told that freeon was leaking from my accumulator stem so i got a new one. then i was told that i needed a new compressor got one and filled...
Call the better Business bureau if you are in the states. if they havent fixed your system thats a huge issue at this point and you have rights.
But back to your problem. The evaporator is normally the first thing to spring a leak. If you are leaking freon there would be the first place to check. Add dye to the system and top it off making sure to have the UV flashlight ready. If the evap is leaking the dye should end up under the car as the condensor drains will empty there. Also check hoses and fitting.
Next get a can of freon with stop leak, a big can and add freon with car running a/c on full blast and keep the pressure at 35 psi as it cycles and drops pressure add more freon. this will take 5-10 minutes to get the system full. When the car is full the low side will read high like about 75 psi which is normal.
Only 1 problem tho if your system has had a bad leak and open to the air, the dryer should be replaced before you put new freon into it. That dryer takes internal moisture and keeps it from freezing in the system.
May 18, 2010 | 1984 Chevrolet Caprice
Where do i put freon in to fill it up whirlpool 12000btu
I assume you do not have any a/c cert. so you must be looking to add R-134, to a automobile you will see a cover sometimes black sometimes blue (NEVER RED) The refrigerant will go in at the fitting under that cap but you want to be sure to put it in on the low preasure side of the compressor. this should also be done with a gauge set so not to over fill the system. over filling will also cause the compressor to shutdoun as well on over preasure situation.
Good luck
Jul 31, 2009 | Heating & Cooling
Need to know where to fill it and how
ON THE PASSENGER SIDE, UNDER THE HOOD YOU WILL FIND TWO ALUMINUM PIPES THAT COME FROM THE COMPRESSOR AND THE ACCUMULATOR(BLACK CYLINDER ON THE FIREWALL) ONE WILL BE LARGER THAN THE OTHER. THIS IS THE ONE YOU WILL BE FILLING UP THE SYSTEM WITH. ON THE SERVICE PORT YOU WILL SEE AN "L" FOR THE "LOW SIDE" WHICH IS ALSO CALLED THE SUCTION. HOOK UP THE FREON BOTTLE TO THIS FITTING WHEN YOU HAVE THE A/C ON AND IT SHOULD GET DRAWN INTO THE SYSTEM. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK AND THANKS FOR USING FIX-YA
May 04, 2009 | Hyundai Motor 2002 Elantra
I own a 1993 toyota camry, my a/c does not work. I was told that in order to add freeon I would need to get it retrofitted because it does not take the 134 freeon, is there any way around this? ( I hope I...
R12 freon has been discontinued due to ozone depletion there for we have r 134a which is just as good but wont hurt the attmosphere you can do a conversion to 134 by changing the fittings to put freon in system you dont have to really change anything else
Apr 24, 2009 | 1993 Toyota Camry V6
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
