Question about Sony Computers & Internet
Systems refuses to boot while the power is still on. It appears it is in a sleeping mode
  • 2,229 Answers
If the power is on, what is it you are trying to do?
If you are running Vista, there sometimes is a problem waking up from hibernation.
To restart the computer, you need to unplug it and remove the battery.
After waiting maybe a minute or so, replace the battery and plug it back in and see if it starts.
Posted on Jul 31, 2009
How do I take desk top out of sleep mode
Wiggle your mouse!
I have had a comp which refused to come out of sleep mode. In the end I had to set it not to go to sleep. To do this goto Control Panel > Power Options/Schemes.
There you will see a choice of times 'before going to sleep', including 'never'. Try to avoid this if possible as it adds a lot to wear of hard drive
Dec 29, 2013 | Computers & Internet
Samsung blue screen sleep
Blue Screen Sleep? Is it it sleep or hibernation mode or are you saying the Blue Screen Of Death (BSOD) which will not allow you to boot successfully?
If it's in sleep or hibernation mode, then check your Power Options in the Control Panel. Set the sleep or hibernation up high or set it to NEVER. Click Start/Control Panel or Start/Settings/Control Panel and look for the Power Options.
If it's the Blue Screen of Death that is preventing windows from booting up, try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 09, 2012 | Samsung Computers & Internet
My dell inspiron 1545 refuses to boot after gone to sleep
This happen to my 1525 and XPS system when I upgrade to Win7. Check your power option by going into your control panel --> hardware and sound --> power options -->advance setting or just click the battery icon on the bottom right by your clock and click "more power option". You can change it to where it will not turn off your hard drive when in sleep mode. I recommend checking the Dell recommended setting. You may also need to update your bios, system firmware and hard drive drive firmware. you can download from Dell support. Enter your service tag # to get the right firmware specfic to your system. If it still fail than you will need to take it to a tech for more troubeshooting of the hard drive or mother board.
Jan 09, 2011 | Dell Computers & Internet
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
Hi I work at a school and have had several convergence machines refuse to boot up. It takes me to the "safe mode etc." option screen but then idlessays monitor sleeping then tries again to boot and goes...
that happens because you have operating system problems, even in safe mode go to the start menu and chose restore system to a previous date when the computer was working fine
Jun 12, 2010 | Computers & Internet
Sleep mode problem
hey , first go to same mode in ur PC by pressing F7 .
thenblue window will appear so there select normal mode . thus ur PC will never go to sleep mode.
Jan 22, 2010 | Dell OptiPlex GX270 PC Desktop
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
