Question about Mitsubishi Televison & Video
WD60738 Mitsubishi 3D DLP replaced lamp for the first time turns on after few minutes hear clicks screen flickers distorted colors.Turns off red light comes on.Checked lamp reinserted same symptoms.
  • Mitsubishi Master
  • 2,005 Answers
You must "tell" the set that it has a new bulb consult your owner's manual as to how to do this
Posted on Mar 15, 2018
  • 1 more comment
  • Viorel Bucur
    Viorel Bucur Mar 16, 2018
    Checked manual twice ,no mention of how to "tell" set has new lamp.
  • Jim Goldsmith
    Jim Goldsmith Mar 16, 2018
    http://www.stereoandvideorepairco.com/Tr...
  • Viorel Bucur
    So,it turns on and green flashing, then turns on for about 2', starts flickering and I hear noises fr.lamp area then colors start mixing weird and after about another 2' turns off and steady red light.ordered an OEM lamp to try, even though the lamp I replaced is new?
SOURCE:
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Posted on Oct 31, 2009
Testimonial: "no wonder you are an expert, we are nothing without you. huge thanks"
SOURCE: I have Mitsubishi WD-Y57 DLP.
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Posted on Dec 01, 2009
TODDAS
  • 431 Answers
SOURCE: MITSUBISHI 73 INCH 1080P DLP
turn down volume see if you hear a noise from back where color wheel is located
Posted on Jul 24, 2011
  • 49 Answers
SOURCE: mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Posted on Jul 17, 2012
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
82" Mitsubishi DLP tv Picture Blinks every few minutes
your Lamp is on the Way out. You will need to replace this in the Next 4 months, This is the First sign of the Lamp failure. How old is the TV?
Nov 10, 2013 | Mitsubishi WD82738 82" inch 3D Ready DLP...
Change out original bulb now flickering picture, help.
You haven't specified here about have did a lamp time reset after lamp replacement. It should be done. If you wish to know more about how to reset lamp time, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there. You can get details. Do this, and check it again. If you want any more assistance, be free by commends.
May 27, 2013 | Mitsubishi WD60738
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Televison & Video Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
