Question about Western Digital My Book Essential Edition WDG1U7500 - Hard drive - 750 GB - external - Hi-Speed USB
WD Mybook I TB hard drive won't power up
I went to go use my WD tb today and there was no blue light, and basically no power going to the unit. Does this mean the drive is toast or I just need a new power cord?
  • 1 more comment
  • bsaeng84 Jul 31, 2009
    The wall outlet I plugged it into has power and so does another power strip I have in the house..
    WD says the same thing but I won't know until I recieve one. I guess I'm gonna have to try out a buddy's power adapter in the meantime and see if thats the culprit.
  • bsaeng84 Aug 08, 2009
    WD sent a new power adapter. Still didn't work.
  • 31 Answers
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Posted on Jul 31, 2009
  • barrymtm Jul 31, 2009
    It is most likely the power adapter but the only way to tell is to get another known good adapter and give it a try. There is also the possibility that the power port on the drive enclosere was damaged. with the USB cable disconnected plug the power adapter into the wall and the enclosure and listen for the hard to start up. If you hear the drive then you have power. It could then be that your computer is not recognizing the drive when you connect the USB cable so you would then need to try a different USB cable and also try it in a different USB port.
I had this same problem and came across your post looking for a solution online, but didn't find one.
eventually i did get it to start working again. i pluged in an adapter from another device that fit but had a higher output voltage. the hard drive light came on for a second and then nothing. after that, i plugged in the original cord again. all of a sudden it worked. not sure this is a technical solution or just good luck, but if you have a similar adapter lying around with a higher output, try what i did.
Posted on Aug 20, 2009
1 TB My Book Live Western Digital, light starts up blue then after trying to discover goes red, tried new eternet cable and still going red. Reset my router and have tried plugging hard drive right into...
I have SeaGate FreeAgent GoFlex 500GB external hard disk and it shows only 230GB. I formatted it many a time but still shows 230 Gb only..Please help me to fix the problem....
Sep 11, 2013 | Western Digital WD My Book Live 1 TB...
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
My Western Diagnostic My Book is not showing up in
That happened to me but with windows. I ended up having to burn a Knoppix Linux boot disc and when i booted up with Linux it was able to access the drive and i tediously backed up my files to another drive and formatted the broken drive and that fixed it. It was a while back so i may have forgotten something but having a Knoppix disc has gotten me into a lot of broken drives. Good luck.
Nov 13, 2012 | Western Digital WD My Book Live 1 TB...
Mybookworld is not comming on
Without taking it apart it would be difficult to diagnose. I would venture to guess that one small component broke internally. You may be forced to purchase an external HDD enclosure, and move your drive.
Dec 15, 2017 | Western Digital 500GB MyBook Office...
Western Digital 1 TB not recognized windows XP
disconnect it and reconnect
if its still not working then we can try the reg fix
Dec 07, 2009 | Western Digital MyBook Studio 1 TB USB...
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
Oct 03, 2009 | Western Digital MyBook Studio 1 TB USB...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
MyBook 1TB will not power on anymore. I have(had) mydocuments pointed to it and it has worked fine until today. My pc said it could not open the selected drive because it was not there. So I unplugged the...
I have the same drive guy. take a voltage meter and test the power adpator and see if your getting the right power to the unit. Check your usb ports as well even try it on another computer to diagnose your own. Try these steps good luck
Apr 22, 2009 | Western Digital MyBook Studio 1 TB USB...
WDC WD1600 netcenter with 1 TB external WD MyBOOK
just called western digital and the solution is: buy an 500Gb disk, that is the max this machine can take....
Nov 21, 2008 | Western Digital Essential NetCenter...
Western Digital My Book Essential Edition WDG1U7500 - Hard drive - 750 GB - external - Hi-Speed USB Logo
424 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
