Kenmore top load washmachine model 4563291
Drum seems to be unbalanced how can i fix this and while i was under the machine i noticed that there were 2 i think shear pins in a plastic holder as if they are being stored for future use if there was a problem??
  • 249 Answers
The brackets that hold drum in place, are probrobly broken. close Ireland bye bye
Posted on Nov 24, 2007
Noticed plastic slivers in the drum and under the rubber boot.Is the from the drum being unbalanced
Could be that the 'spider' mount for the drum is broken and the drum is catching on the surrounding plastic outer drum.
Mar 15, 2016 | Kenmore Elite 45986 Front Load Washer
We have a kenmore washer HE11045862400 . It is 7 years old. Excellent condition on the out side. We have notice it making a loud noise when it is in the spin cycle . Machine at times moves . It cost us...
Your drum is going unbalanced with the load.
Either you do have an unbalanced load but more likely is that the dampers on the underside of the drum have failed. (they are like shock absorbers).
Normally there are springs at the top the suspend the drum and on the underside there are dampers.
There normally are 2 dampers attached to the drum and the frame.
They are accessed by tipping the machine onto its side.
However the machine is heavy and make sure you disconnect power and water if you want to investigate.
Cost of new dampers are around 50 each.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Kenmore Dishwashers
I took my basket out because of an unbalancing problem and water is trapped inside of the basket. The water will not come out. Will this cause my unbalancing problem?
Normally excessive shaking etc is caused by 3 things.
1) Unbalanced load. 2) Brocken spring that suspend drum. 3) Dampers under drum lost damping.
I would expect 3 as likely cause if machine works ok except for when spinning.
Feb 05, 2011 | Kenmore Washing Machines
How do I rebalance the drum on a kenmore series 80 washing machin
Check to see if one of the springs supporting the drum has come off during the move.
Apr 11, 2010 | Kenmore 24032\24036 Top Load Washer
Washer wobbles
Its the clutch and its causing the drum to spin unbalanced It will need replaceing and a new sealed bearing too
Please rate our help to keep the free service online ++++
Aug 30, 2009 | Kenmore 24032\24036 Top Load Washer
Unbalanced spinning
Remove the outer cabinet and inspect the springs and the plate under the tub.
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE Top Load
there are 4 rods holding the drum up, check to make sure all 4 are attached.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Sloppy play in laundry drum
it sounds like the main drum bearing has gone you should call a local engineer to confirm good luck
Mar 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
