Question about Kenmore Washing Machines
My agitator is not turning all the way on full loads. Are these belt based?
    Brigadier General:
  • 3,513 Answers
The reason for the washing machine not agitating is due to a faulty coupler.
Replace the coupler. Cost about $35.00. It is located between the motor and transmission. This will solve your problem. Easy to fix. About 30 minutes
Thank You for using Fixya.com
Posted on Jul 31, 2009
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Maytage la610 - Newton - old style counterweight transmission (mfgd.1981)
It is possible that the motor may be on it's way out. You might check to see if it has a start capacitor on it that may be getting weak and possibly by pushing the agitator takes the initial load off of the motor. Just a thought.
May 14, 2014 | Washing Machines
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
LG Top load fuzzy logic washing machine only washes small loads
Please check if the drive belt to the main motor to the agitator is slipping or is loose. It is also possible that the agitator is jammed and so could have friction so that the belt slips.
Aug 17, 2012 | Whirlpool Washing Machines
How to change belt on whirlpool ultimate care plus washing machine
Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
May 19, 2012 | GE WBSR3140DW Top Load Washer
Frigidaire top loader tries to agitate. How do I fix?
Sounds like a drive belt slipping. Look under the base and see if the belt is tight between the motor and agitator base
May 09, 2012 | Frigidaire Washing Machines
Kenmore:Noise; agitator not working; drum full of water...HELP!
Sounds like you have a broken motor coupler, check the tutorial at www.shop.washermd.com dave
Jan 12, 2009 | Kenmore 15944 Top Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
