SOURCE: Setting clock on Amana Microwave Mod#FBG623T
Get owners manual free from Whirlpool at this link
http://shared.whirlpoolcorp.com/assets/pdfs/literature/B8383295.PDF
It tells you how to lock and unlock the keypad and set the clock etc.
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
SOURCE: Set clock time on microwave oven
I have consulted the Owners Manual and there is no mention of the demo mode. I would suggest that you unplug the unit or disconnect power if it is hard wired in, and try to set the clock then.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
SOURCE: sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
SOURCE: my maytag microwave keeps beeping it
"SE" means you have a shorted membrane keypad.
On some models, you can replace the membrane keypad.
I have
uploaded a handy guide with pictures showing you what's typically
involved. It's here.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
On some models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Some connectors on the relays may have a lock:
