My servis automatic is not letting in hot water on any wash..is this a thermastat problem..and how much roughly to repair?
  • 24 Answers
Sounds like the hot water valve. repair would cost about £57 if this. check to see there is hot water getting to the machine first.
Posted on Aug 05, 2009
  • douglasbmack Aug 05, 2009
    sounds like the hot water valve. repair would cost about £57 if this. check to see there is hot water getting to the machine first.
Washed 1997 expedition engine.. now runn ing rough
im not to sure but if washed the engine while the engine was hot u probably cracked the engine block which is a LOT LOT LOT of money to repair. its like throwing very hot plate into freezing water the plate will break into pieces same concept as a hot engine and cold water they dont mix at all
Jul 16, 2012 | 1997 Ford Expedition
Tip
I'm having the FH error. I'm am currently having plumbing troubles after leaving...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on May 27, 2010 | Kenmore Elite 45986 Front Load Washer
My dishwasher has always washed in cold water never had any hot water why is that
Probably because it is hooked up wrong...
The water feeding it should be hot water... meaning it should be hooked into you hot water piping, not the cold water...
The dishwasher will keep hot water hot but it is not powerful enough to heat the cold water up...
heatman101
Jul 16, 2011 | Servis 23 in. M4306 Free-standing...
Manual instruction for servis caress 1200 a
i want to connect a hot water to my caress1000`a`
is it possible?and how our washing machine could control the temperature.(washing machine has a cold water connection)
Aug 31, 2010 | Washing Machines
Servis model M3905W does it matter if the hot and cold water are connected up the right way round and if so what isthe right way round?! Thanks
Makes a big difference. Cold water valve is is normally marked blue or simply cold water. connected to cold water tap. Hot water marked with red colour or simply hot and connected to hot water tap.(Red hose - Hot water. Blue hose- cold water.).
May 27, 2010 | Washing Machines
Help please i have a servis m6000-1 overheating
Frst of all check that the incoming water supply is cold water to the washer, if you can verify it is, then it sounds like it is not rinsing, so I would suspect a blocked pump filter or pump.
You need to check that it is draining properly.
May 24, 2010 | Washing Machines
Whirlpool washing machine water not hot enough
This so called "energy saving" ...That's why they build in this nonsense. Some dumbo in some office somewhere just thought it up thinking that will save the energy. I fact ,that way I have to wash same stuff twice because water is not hot enough ...
Apr 07, 2010 | Whirlpool WTW5300SQ Top Load Washer
Replaced radiater ,thermastat still no heat and
Did you run engine from cold, WITH HEATER ON, and fill cap off when re-filling system? If not, try that and see what happens. Let the engine get up to operating temperature and rad fan come on to cool 2 or 3 times before putting cap back on.
Nov 17, 2009 | 1995 Subaru Legacy
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
My Servis M6000-1 washing machine does not fill with water
Buy a new washing machine, seriously, i had a servis M6002s, only had it for 13mts and it died, it wouls have cost £130.00 to repair. After doing a few online serches for the machine i found loads of other people with th same problem. I was outraged to be honest, granted they are not the most expensive machines out there but if you pay £250.00 for a washing machine you expect to get at least 3 yrs out of it. Needless to say i won't be buying a servis again, absolute rubbish.........
Aug 22, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
