SOURCE: help
charging flash means then the camera is charging the flash light,, thats not a problem,, just wait for a couple of min, , and then take photos,, hope i helped ya
SOURCE: card locked on camera
Hi there, to fix this, do this:
Remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
SOURCE: where can i find a manual for a hp photosmart digital camera435??
www.tradebit.com/.../8685645-hp-photosmart-435-digital-camera-manual -
Copy and Paste above link in your address bar to go to your manual
SOURCE: where can i get the dock for the camera??
Depending on the model, but most Best Buy stores, or any electronics stores and Walmarts or Kmarts may have what you need. If for some reason none of those have it, check on Craigs list, or Ebay.
SOURCE: HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
