Question about Microsoft Xbox 360 Console
Wireless connector not connecting to xbox live via router will connect when hardwired
  • 35 Answers
Well i had a similair problem....the problem is somthing is interrfering with the wireless signal like a wireless baby monitor, high powered microwaved, or somthing like that
Posted on Jul 31, 2009
Accidently disconnected xbox live and now it wont reconnect
reconnect xbox live via wireless and find your conncection source.. if you have a passcode on your internet connection . use it . if it was hardwired . use the instructions used to connect it up... go to xbox support if you have issues..
Oct 23, 2011 | Microsoft Xbox 360 Elite Console - Black
I HAVE A WIRELESS ROUTER DOES MY PC HAVE TO BE WIRELESS BEFORE I CAN CONNECT X BOX LIVE
Your pc doesn't have to be wireless, you should be able to connect to it through your router as long as it is wired in. To connect to xbox live, you either need to get a wireless adapter for your xbox 360 or connect it via ethernet to your router.
Nov 22, 2010 | Microsoft Xbox Console
Trying to get xbox live
reboot your modem and router, then try again...by the way, how are you connecting the 360? hardwired or wireless adapter? either way, you should reboot both.
Apr 05, 2010 | Microsoft Xbox 360 Console
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Turning the xbox 360 into xbox 360 live?
ok, so if you want to do it wirelessly you need to get the wireless network adapter for the 360. i got mine at target for about 100 bucks. You also will need a Xbox live Gold card if you are wanting to play with your friends. you can also get your subcription over the xbox by using a credit card. The setup is pretty simple, just follow the on screan instructions. I am assuming your dashboard uses the "blades". if so, go over to the marketplace section, and go to join xbox live. then it will guide you through the process.
Hope this helps you.
Feb 08, 2009 | Microsoft Xbox 360 Console
Netgear 624
to set upa network
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
there is no "earthnet" connection. it is an ethernet connection. it looks like a phone cable but has larger ends than a phone connector. the router is connected to the computer via an ethernet cable if it needs to be hardwired to a ethernet port or internal ethernet card. a wireless connection only needs to be an add-on internal card w/antenna or a usb connector hub (it looks like a usb flash memory stick)
here is how it's done. netgear has the same type setup.
Oct 13, 2008 | NetGear WGT624 Wireless Router
Xbox LIVE
I think the encryption may not be set up on your router or your router isn't broadcasting it's signal. Have you checked the connection of the wireless adapter, I mean that it's plugged in correctly? Not sure what type of encryption it uses but check the manual or box adapter came in and then log onto your router by accessing it via ip address of router in IE address bar. Then check to see if it has the relevant encryption set up. It will either be WEP or WPA or Open. Also make sure the router is set to "broadcast" it's signal.
Jun 24, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
Microsoft Xbox 360 Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
