Question about Lenovo IdeaPad Y430-3231U Notebook
Problem with keyboard
Hi everyone, I'm currently using a Lenovo notebook.
There's a problem with my keyboard. Whenever I type H, hu6 appears, when I type I, i= appears, & G appears as gr5. Due to all these, I've to keep back spacing. It's really getting on my nerves.
Please provide me with solutions. Thanks.
    Problem Solver:
  • 10 Answers
When you hook an external keyboard to it, does it type normally? I am guessing it probably does but you need to test that first. Find a USB keyboard, hook it to it, wait for it to start working and check it out.
If the external keyboard types normally as I think it will then you probably need a new keyboard. If however your computer was damaged by moisture or unnatural compression to the keyboard, a new keyboard may not fix it. Moisture damage or compression damage to the computer can be permanent, but my first guess is a keyboard would do the trick.
Taking the keyboard off a Lenovo (less than 4 years old) is very easy. There about 4 or 5 screws on the bottom that need removed and the wrist rest (which pops out) then they keyboard comes out pretty easy.
Posted on Jul 31, 2009
What happen to my keyboard? When i typing button '@', sign " will appear. And same situation when i typing button ", sign @ will appear. Look a like " and @ swap. -fairulazwan@gmail.com-
You are using wrong keyboard type.
Numeric button 2 has @ sing in USA Keyboard and in UK Style Keyboard Numeric Button 2 has ".
Dec 26, 2014 | Lenovo Keyboard
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
How to troubleshoot hp G56 keyboard when different letters appear when typing a certain letter for example when typing letter s letter w will also appear and so on and so forth
1. Do a BIOS memory test, to check your notebook memory.
2. If OK, make a system backup of your current installation on an external medium.
(just in case you want it back later)
3. Recover the factory setup installation and check the keyboard if it is working OK.
4. If not, the mainboard of the notebook is probably faulty.
Oct 07, 2011 | HEWLETT-PACKARD G56-141US Notebook
Unable to type the character C on my lenovo G550 laptop?
For that problem. you need to install external USB type keyboard, for my experience that on-board keyboard cannot repair only replace same keyboard specification compatible for your Lenovo G550 PC notebook.
I hope this information will be helpful.
Thanks for using FIxya.
Jul 26, 2011 | Lenovo G550 Notebook
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
All my keyboard only showed 0123456789
This is a problem particular to Lenovo Ideapads. I just found the answer in the Lenovo forums. The fix is simple & quick:
http://forums.lenovo.com/t5/IdeaPad-Y-U-B-V-and-Z-series/Game-keyboard-problem/m-p/298246/highlight/true
http://forum.lenovo.com/t5/IdeaPad-Y-and-U-series-Laptops/Typed-letters-appearing-as-increasing-numbers-0-1-2-3-4-5/ta-p/301034
Nov 05, 2010 | Lenovo ThinkPad T42 Notebook
My girlfriend's hp is jacked up. whenever she
Hi, the problem is coming from the keyboard. you can test by plugging an external keyboard and try typing on the external. you can replace the laptop keyboard if necessary.
Jan 26, 2010 | HP Pavilion dv5tse Notebook
Replacement keys for keyboard
E-bay my friend. E-bay.  You can purchase individual keys for the keyboard or buy a whole keyboard and replace keys whenever you need to.
Nov 01, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
Whenever I type in a document the cursor jumps to another location, anywhere anytime. i have already disabled the touchpad and also clicked the disable when typing box in the control panel. I have a lenovo...
This may be a software or driver conflict. Look for out-of-date apps. Look for version numbers of all apps, games, utilities. Belarc (free at belarc.com) is a simple tool to gather all the version information on your computer. Confirm that each program's "system requirements" list your current OS level by visiting the software manufacturer's site and checking for your specific software or driver version. Either remove or update any that are not specifically compatible.
Oct 21, 2009 | Lenovo 3000 G530 Notebook
Lenovo IdeaPad Y430-3231U Notebook Logo
485 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
