it wasn't the element, it was the clock timer control board. Had power going in nothing coming out to the elementit wasn't the element, it was the clock timer control board. Had power going in nothing coming out to the element
AnonymousJun 24, 2008
Mimi's electric built-in oven,mod. C970-416121, ser. NF 12513183, doesnt heat properly, stops often, what can I do to solve problem at a low cost?
Thanks !Mimi's electric built-in oven,mod. C970-416121, ser. NF 12513183, doesnt heat properly, stops often, what can I do to solve problem at a low cost?
Thanks !
AnonymousMar 15, 2014
THE PROBLEM IS INTERMITTENT SOMETIMES THE OVEN HEATS PROPERLYTHE PROBLEM IS INTERMITTENT SOMETIMES THE OVEN HEATS PROPERLY
AnonymousMar 18, 2014
Oven switches of after half hour of heating upOven switches of after half hour of heating up
You can't post conmments that contain an email address.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
yes sounds like your bake/broiler relay is sticking closed. this could possibly be a $400.00 repair. look in your owners manuel sometimes they give extended warrenties in there. so all you would be responible for is the labor. let me know how it goes.
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
look inside the oven and check to make sure the thermstat is in the right place,also check to see if you see any burn out spots on the element,let me know what you find-mike
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
nevermind fixed it
Thanks !
