Question about Frigidaire FEQ1442ES Electric Dryer
My husband pulled the cord out and was mildly shocked (he is fine) but now the dryer wont spin,is does turn on but when you press start it does not- is there a reset button?
    President:
  • 1,273 Answers
If the cord shocked your hubby, the problem is with the cord! It runs on 220 volts, with half (110v) on two seperate wires. One of your wires is shorted or burnt. Unplug the dryer. Pull the dryer out to where you can see where the electrical cord enters the dryer. From the wall, the cord should pass through a strain relief clamp, into the dryer, and then connect to the terminal strip. Many people eliminate the strain relief clamp, and wish they hadn't later. Anyhoo, open the cover plate that covers the wiring in the back of the dryer, and inspect the wiring and terminals. If a shock occurred, the cord probably needs replacing. Purchase a similar cord (~$15), install it through the strain relief into the hole below the wiring access cover on the back of the dryer, and make the wiring connections. For a three wire cord, the outside wires are the hot leads and connect to the dryer, one to the left, one to the right. The middle lead is the neutral, and connects to the middle terminal. Tighten the strain relief, and replace the wiring access cover.
Hope that this was helpful. Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 31, 2009
Samsung dryer wont spin and the control board clicks when i press the start buttonModel DV331AER/XAA
start by pulling off the top and see if the belt is broken or not. some units turn off power to the motor is the belt is broken. a common problem
Sep 15, 2016 | Samsung Dryers
We have a toro model 20031. The battery doesn't work and my husband disconnected all battery connections. Should the engine still start with the pull cord?
leave all the battery connections connected, then prime the carb, and pull to start, i have a quad with an electric start and a pull start, it will not start with the pull cord if the battery is not connected.
Dec 14, 2014 | Toro Garden
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
It worked fine one morning when my husband used it and then later that day it just wont turn on at all. we tried all different settings and the on button just wont kick it on. Could it be a fuse? or plug?...
need make and modal but you should check and see if the drum turns with not much resistance if so the belt could be broken. On some brands they have a switch to turn the dryer off if the belt breaks. If one of the two fuses supplying the dryer is open the dryer may not start.
Oct 28, 2010 | Dryers
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
Duet dryer
be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
May 28, 2008 | Dryers
Not spinning up
Sounds to me like a bad motor. brushes in the motor may be worn or broken FTF530 Has a coin trap and filter that should not keep it from spin cycle. let me know what you find out.
Sep 08, 2007 | Frigidaire FTF530FS Front Load Washer
Frigidaire FEQ1442ES Electric Dryer Logo
176 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
