Question about Microwave Ovens
Microwave want heat any longer. Everthing else is
Microwave want heat any longer. Everthing else is working fine
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Jul 31, 2009
Why wont my microwave heat when everthing else works?
The unit is not producing microwaves, therefore replace it.
May 03, 2014 | Rival RGST902 - 0.9-cu ft Microwave Oven,...
Everthing works but won't heat
If turntable works suspect inverter (power) or Magnetron itself is bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
My GE microwave Model #JE1860BH 03 will not heat. It started to arc for a few times then quit heating. Everthing else works. Can you help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
Kenmore microwave model 721.80033700 won't heat
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
Food not heating in microwave
Magnetron tube probably failed. Depends on how old the microwave is. If its still under warranty, call Frigidaire. If not, take it to a repair shop, get an estimate, and compare it to a new one. It'll probably be cheaper to buy a newer one that will have more power, but check anyway.
Dec 18, 2008 | Frigidaire FMV145K Microwave Oven
Microwave Ovens Logo
134 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
