Question about Mintek DVD-2580 DVD Player
Password Parental level of player been set on my DVD player and i need to reset the password please infrom how do i go about doing so.
  • 4 Answers
Re: password
The best I can do for now is suggest entering 88888 as the password. This is the password as set by the manufacturer. If you or someone else has changed the password then I cannot help you. I do hope this helps.
Posted on Jan 06, 2008
0 characters
3 Points
Parental controls
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Jul 07, 2013 | DVD & Blu-Ray Players
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Apr 09, 2011 | Zenith DVB412 DVD Player
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
Mar 24, 2011 | Toshiba SD-K740 DVD Player
My grandfather cant remember the code for parental controls. it is stuck on pg. can it be reset with out the code
Forgotten the parental control password? there is a way around this. According to the user manual (page 34) for this particular model:
Enter "788444" even if 4 digits "----" appears, then press [ENT]
to clear the current password.
Enter a new password and set the parental lock level again if required.
Note: DVD video discs may or may not respond to the parental lock
settings. Make sure this function works with your DVD video
You need the original unit's remote to do this. It cannot be done without it.
There is a .pdf of the user manual online.
(It is free to download for personal reference in case you have lost your original copy.)
I hope this helps a tad.
Mar 07, 2011 | Sanyo DWM-390 DVD Player
My DVD player is locked, the display shows a red key.
Hi, This sounds like a parental lock issue. Try going into the set up menu and press the down key choosing custom by pressing enter (this is in the user manual page 20 - 22) then go down and select parental. If you know your parental control password code then enter it, if not the reset code is 4737 you will then need to create a new 4 digit code,There are 9 levels to choose from 1 - 8 and all, all being the selection that removes the parental lock. Hope this helps. James
Apr 21, 2010 | Sanyo DVW-7100A DVD Player/VCR
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Re set passwords 3256
when enter Mp3 player to DVD player, DVD want password. kindly infrom reset password
Pabitra kr. Das.
Jun 22, 2009 | Philips DVD625 DVD Player
Can't get the Initial Settings screen
Hi,try this...with the dvd tray open,hold the rec button and play button on the dvd for 5seconds.hope this helps?
Mar 25, 2009 | Panasonic DVD-A110 DVD Player
Password unknown
  1. Press power on from a cold start with no disc in the unit.
  2. Press the STOP and PLAY buttons simultaneously on the front panel for three seconds. “All setup value will be reset to factorysettings. Your player will be shut off.” will appear.
  3. Press the MENU button on the remote control to select the Parental Mode. The Parental Mode is now unlocked as indicated on the display.
  4. Press the DOWN button to select Parental.
  5. Press ENTER and the Password Check display will appear.
  6. Enter the default password of “9999”.
  7. You can now set your rating level and change your password to a new number.
Mar 13, 2009 | Samsung DVD-N501 Nuon DVD Player
Mintek DVD-2580 DVD Player Logo
151 people viewed this question
Top Mintek DVD & Blu-Ray Players Experts
Jaime Hernandez
Are you a Mintek DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
