Question about E-Machines eMachines Desktop PC
All i get is a logo
When i boot the computer all i get is a big
when i boot the computer all i get is a big
emachine logo that fill the whole screen
    President:
  • 1,383 Answers
Open your cpu cabinet.
Then Refix RAM memory.
Pull cmos cell from motherbord chipset for 15 minutes then all motherbord bios settings are defaults.
Then check.
Posted on Jul 31, 2009
How do i change boot order on emachine t3604
You will need to change the boot order in the bios set-up.
Turn your computer off, and turn it n again (alternatively Restart it) These things may be initiated by clicking the Windows button at the bottom left of tour screen, and from the shut down drop down menu selecting the appropriate option) As your computer is starting up, and the Emachines logo appears on the screen
"Press the "Tab" key repetitatively: If that fails to take you into the BIOSsetup, repeat and try either the "Escape," "Delete," or "F2" keys instead of the Tab key.
Once in the BIOS setu[p, Look through the options until see Boot order, and then change that to CD first, HD 2nd. Exit the BIOS setup with save changes option. Done.
19.February.2015
Feb 19, 2015 | eMachines T3604 PC Desktop
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Cant get to boot screen to start recovery on e525. I tried every f key! Only get e logo screen which will flash to a black screen with blinking cursor at top left then flashes to all black screen back to...
Some of the emachines coming with Recovery image. You need to press F11 key on starting to check whether the image is available or not. If it is there proceed with restore.
Otherwise you need a recovery CD to do this. If you don't have any CD then you could purchase the recovery disk for your emachines from the link below by entering the serial number on your computer:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Apr 02, 2012 | Acer Computers & Internet
How to change the boot priority on emachine?
eMachines - eMonster, eTower, eOne, S-Series, T-Series;
Press Tab or Del while the eMachine logo displays on screen.
Other eMachine computers may use F2 to enter BIOS.
HOPE THIS HELPS
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | E-Machines eMachines Desktop PC
Display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Nov 25, 2009 | Acer X203H bd Monitor
Emachine d620 how to factory reset
when you restart the laptop press f2 then disable the f10 boot menu then restart your computer again after the emachines logo appaeres press f10 repaetedly until the factory defualt festore screen apeares then follow on screen directions
Jul 04, 2009 | eMachines eMD620-5133 Notebook
Blue Screen
When the computer first boots up, press the F8 key when the eMachines logo is replaced by the first Microsoft screen, then select Safe Mode from the list. If the computer will not boot in Safe Mode, you will need to boot from your Windows CD and select the repair installation option. If you can boot in Safe Mode, you will need to find out what is causing the system to reboot during startup. With the msconfig utility, disable all unnecessary startup programs and services, then try restarting the computer normally. If this works, you need to use the msconfig utility to add the startup programs and services back one-by-one until it fails to boot again (to locate your troublemaker). Keep repeating this until all services and programs (except the one causing the problem) are back in the lineup.
Jun 01, 2009 | E-Machines eMachines Desktop PC
Need to access intel graphics application
1. Turn on the computer.
2. Access the safe mode screen. To do this tap on the F8 key after the logo goes away on the screen until the safe mode menu appears. Select VGA mode.
3. This will boot into 640 x 480 resolution, everything will be very big. Now you can go into the properties and select a mode that your monitor can handle.
4. Finally, please rate this solution as fixya as I have answered your question completely with the information you gave me. Thanks! :c)
Jan 25, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
88 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
