SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
SOURCE: Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
SOURCE: I have a Janome Memory
Before you take it for a service, how about cleaning the bobbin case. You have to take off the metal plate but them it lifts out easily. get a manual on line to show you how
SOURCE: my brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
