Question about Makita 2703 10" Table Saw, Electric Brake
Table is "humped" 1/16" in middle of table. How can i level my table back down?
  • 2,176 Answers
Is it the table or the insert that is humped. I have never heard of a table especially in the middle being humped. I would recommend that you call 1-800-4625482 that is the Makita Tech Support line and see what they can come up with versus replacing the table
Posted on Aug 10, 2009
What is a coffee table?
A coffee table is a table that is long and low. It is meant to be at the same level as your couch and is generally used for drinks and finger food.
May 29, 2012 | Furniture
I am just setting up my new Skil bandsaw, and the table is not level--won't go to 0 degrees. Is there an adjustment I'm missing?
usually there is a stop bolt under the table that you can adjust so that you are able to zero out the table. it should have a lock nut so that when you get the table set to where you want it you can lock down the bolt so that the table is easily re set after moving the table for an angle cut.
Mar 15, 2011 | Skil 338501 9inch Band Saw
I have a Delta 17-950L drill press. The table is perfectly level according to my level. In checking I find out that the chuck is not coming down completely vertical. An eighth of an inch in a four inch...
You don't want the table to be perfectly level, it does need to be perfectly perpendicular to the quill. If the motor housing or quill is not be perfectly straight up and down, as appears to be the case with your drill you will need to square the table to the quill, both left to right and front to back.
Feb 10, 2011 | Delta Laser Crosshairs Drill Press...
We have a DeWalt 744 table saw. The motor will not start. Is there a reset switch on the motor? We have checke dthe electrical supply and it is good
check on the motor housing.
for a hump, that contains a capacitor ,
have it checked.try changing it with a different capacitor but the same (uf).
check to make sure that it works
Dec 10, 2009 | Saws
6150 scans leave a line down the scanned image
There is probably a speck of dust on the scanning unit. You can unlatch the glass scanner table and, with the unit powered down and the cord unconnected, gently pull the scanning unit out (or you can start a scan and power down the unit when the scanning unit is in the middle of the table). Opening the scanner table will void your warranty!
Examine carefully the glass "window" of the scanner in the area corresponding to the dark line using an angled light and see if you can spot the dust. You can clean the window glass with a lint-free cloth dampened with alcohol. Do not press hard on the scanning unit since the mechanism is quite delicate. Afterwards, carefully replace and latch back the glass table.
If the dark line does not go away, you might have a faulty scanner, but that's unlikely.
Oct 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
Visual basic program for binary search technique
This sounds like "homework".
A binary-search requires an "ordered" table of values.
Sort your values into the proper order.
LET TOP=1; * Point to first element in the table.
LET BOT=1000; * Point to the *LAST* item in the table.
LOOPHERE:
LET BINARY = 2;
LET MIDDLE=FLOOR((TOP+BOT)/BINARY);
IF VALUE(MIDDLE) = KEY THEN STOP;
IF KEY < VALUE(MIDDLE)
THEN TOP = MIDDLE;
ELSE BOTTOM = MIDDLE;
IF TOP = BOTTOM THEN STOP;
GOTO LOOPHERE;
END;
Mar 08, 2009 | Microsoft Windows Vista Home Premium with...
Infeed Table leveling
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Feb 28, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
My Whirlpool Fridge constantly has water in the humidity control crisper and sometimes appear on the floor
Sounds like the drain line is clogged. In your freezer you have a drain line that takes the defrosted ice (now water) and goes down to the collection pan under the fridge. Can you take off the back panel and inspect the drain line opening it is located under the coils in the middle. Now it more then likely is ice that has formed and isn't melting, take some regular table salt and with a table spoon put on the blocked section. Just 2 table spoons is all you need to put on it. Hopefully within 20 min. you will have a clear drain and be able to replace the back panel. Let me know what you find out. ken
Dec 28, 2008 | Refrigerators
Makita 2703 10" Table Saw, Electric Brake Logo
252 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
