Question about IBM 4230 Model 102 Matrix Printer
I was printing an envelope that g ot jammed.How do
Lexmark 4530 printer: I was printing an envelope that g ot jammed.How do you remove the paper that is jammed? I tried reaching in thru the top paper feed to remove it, but the envelope ripped,
  • 40 Answers
Remove the cover of the pc and take a 9V battery and put the terminals of the battery to the terminals to the motor which should be right under the roller. if you can't get to it then you have to remove the roller(s)
Posted on Jul 31, 2009
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
Paper Jam inside the printer Lexmark 5470
Firstable, you need to remove these pieces of paper from your printer. It is possible just removing a part of the printer located in the back or the bottom of it. Then you need to know that if you want to print on an envelop, it's necessary to format the printing settings. Just go to printing format and choose envelop
and also the dimensions of the envelop you want to print, then after this it'll be simple.
Dec 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam error
print_friendly.gif null.gif null.gif null.gif null.gif How to Resolve Paper Jams ID:894 null.gif null.gif null.gif
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
Apr 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
Ensure that:
Jan 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
IBM 4230 Model 102 Matrix Printer Logo
174 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
