Question about Kenmore 64802 Top Freezer Refrigerator
Freezer and refrigerator doors are mis aligned after move. gaps where you can see into both compartments. are doors adjustable to fix this problem?
  • Anonymous Mar 20, 2014
    doors are not aligne
    how to align doors
    Sergeant:
    Champion:
  • 205 Answers
Can you see the rubber gasket which will be fixed all the four sides of the door,it should be uniform when you close the door.
Posted on Aug 07, 2009
Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Sep 09, 2012 | Samsung Refrigerators
Gap in large freezer door seal
if you cant adjust the door, ger some weather striping, some that is some what thin. so it can mold to exsisting area
Aug 04, 2012 | Gladiator Freezerator Top Freezer...
There is gap in the bottom part
a gap in the bottom part of what ? if its the freezer door just adjust the door up if its the two top doors with a gap at the bottom of the two doors adjust and the hinge's and ajust both the same .. mm //
Aug 17, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator doesn't work but freezer does double door stainless steel bottom freezer bought in 2006
Check the air circulation fan motor for proper operation. It's located in the freezer compartment. If it doesn't work, replace it. If it's ok, check your door seals for gaps and leaks. Also check for proper door closure and alignment.
Jul 31, 2009 | Refrigerators
Bottom freezer door on our LG is out of adjustment. One side closes tight the other has a .25" gap.
The easiest way to fix that is to pull the freezer door all the way out and give it a good little tug, you will see the plastic covers on the side rails there will be a little gap about one inch on each side make sure those gaps are even. Your door should be aligned
Jul 11, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Model TFA27R doors out of alignment; top of refrigerator door must be moved to right as it rubs against freezer door at top. How do I adjust doors?
Slotted screw on top of door, under a cover, needs to be loosened, adjust the door, tighten. That's it.
Jun 22, 2009 | GE Refrigerators
Bottom freezer door moves top to bottom by moving handle in & out
Hi, most models have adjustment screws near the track connected to the door if this is a slide out door. If this is a swing out door, you might be able to twist the door back in shape.
If the gap is only in the corner of the door, try inserting a piece of paper towl rolled/folded up behind the gasket to help stretch it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LRBC22544 Stainless Steel Bottom...
Kenmore 64802 Top Freezer Refrigerator Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
