Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Profile Arctica 25.4 Cb Ft Side-By-Side Frigr dispenser problem
Does not dispense water or Ice. When you press the water or ice dispensor switch, the refrigerator moter stops cooling and the display panel on the top of the right side display, goes blank for about 10 secs and then turns back on. The icemaker does not make any sounds or movment when attempting to dispense ice. Upon inspection, the protective housing to the icemaker tranformer had ice built up on the inside of the protective clear rubber housing. In addition, when you select the light from the display on the dispensor, the temp display briefly goes blank for approx 10 secs, and the compressor motor stops and then turn back on. Could this be a main control board issue, or could the icemaker transformer be grounding out the display circuit? Any ideas on how to fix? Thanks! Model PS526SGRD SS GE Profile
5 Suggested Answers
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 56 Answers
SOURCE: Hello, I have a GE
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
  • 1606 Answers
SOURCE: GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
It was covered under warranty , at the previous customers residence .
Posted on Nov 20, 2009
Testimonial: "Thanks for the information on the main control board. I replaced it and its working great. I checked the warranty info but mine wasn't covered."
SOURCE: Where is the Dispenser Board located on a GE Profile Side-by-Side
Hallow i have a broblem with my freezer is takes waters all the time to the floor the name of the freezer is whirpool wthat can i do to soal this proplem i send this massege from greece thank you.
Posted on Jan 24, 2010
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
How to repair a GE Profile Arctica 25.4 Cubic Feet Side-By-Side
This might help you...Good Luck!
Sep 29, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile artica profile freezer on top -- refrigerator clicking and not cooling
Check compressor is working. If not, replace relay and check. If still compressor not working, you have to replace compressor.
Feb 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Water won't come out of dispenser. ice works fine
Your refrigerator is equipped with a dual water inlet solenoid valve assembly . It is likely that the solenoid valve that controls flow to the water dispenser is faulty. Click here for a tutorial on How to Test Inlet Valve.
Feb 11, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
