Question about Motorola Mobility RAZR2 v9 Cell Phone
My phone will not power up. It dies after 2 or 3 seconds. I checked the dot for water damage, it is white with red x's. It is a motorola razor
Flip phone screen is white and dot is red
Phone has water damage and needs to be replaced.
Mark
Motorola Support
Apr 01, 2014 | Motorola Mobility Motosmart Flip XT611...
Motorola Q water damage
Probable yes!!! You can try to disassemble and clean contact with alcohol!!! That my advice!!!
good luck! You gone need it!!
Jan 30, 2008 | Cell Phones
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
How do i find out if the motorola cliq im going to buy has had water damage?
when you pop the battery off there is a circular dot near the middle near the orange or black rubber thing that helps lock the SIM in and SD card.
The dot is likely either white or red. White should indicate that it is good and red if it had significant moisture/ water contact.
Apr 01, 2010 | Motorola Mobility CLIQ Cell Phone
How can I tell if my LG Dare has water damage? I don't see one of the white or red round dots that people talk about.
In order to check for water damage you need to remove the back cover and battery and check for a square or a dot on the back of the phone, this is called the LDI (liquid damage indicator). If the LDI is white then its not water damage, if its red or pink then the phone does have water damage. If you don't see the LDI it might have been removed by someone or by the water itself, you need to take it to a Verizon store so the can check the internal LDI.
Hope this helps,
joe
Feb 25, 2010 | LG Cell Phone Accessories Bundle for...
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Backlight not turning on when phone is turned on (Razr)
There is a small cable, inside the phone, near the hinge, that can come loose or unplugged. You should have this checked out by someone who can service it. For them it's a simple procedure of reinserting the cable fully.
Aug 03, 2008 | Motorola Mobility RAZR V3
Water damaged Moto razor
I know you don't want to here this, so be kind with your rating, but the best solution is a new phone. The reason is this: no matter what you do, water is a conductor and the dried residue it leaves behind will also short things out. And water will get to places that you can't.
Sorry, hope that helped save you some time...
Geno
Apr 03, 2008 | Motorola Mobility RAZR V3
Motorola V3 Razor
Under network settings, try to set it to call fowarding disabled
Aug 15, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR2 v9 Cell Phone Logo
136 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
