Question about Metra Chrysler Interface
2000 chrysler cirrus LX 2.4 The car stumbles an bucks
2000 chrysler cirrus LX 2.4 The DTC code p0138 o2 sensor circuit high voltage the light came on and later it went out and the another code came up it was DTC code p0140 o2 sensor circuit no activity detected the light came on and later it went out. I replaced the o2 sensor before the catalytic converter the light don't come on but it still stumbles when I put my brake on at a stop sign and when I am up to higher speeds it bucks and stumbles it does not seem like it wants to take the gas especialy going up hill. when I put the gas to the floor it will jump into passing gear and then it will take the gas and work ok
2 Suggested Answers
  • 11 Answers
SOURCE: Chrysler Cirrus stumbles and jerks on pressing gas pedal
timing belt
Posted on Aug 03, 2009
1996 GRAND CHEROKEE CODE #P0141 AND P0138
Hi there:
Both codes refer at O2 sensor...
DTC P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141. See also: P0135 (Bank 1, Sensor 1).
You will likely notice poor fuel economy the illumination of the Check Engine Light.
A code P0141 may mean that one or more of the following has happened:
open or short to ground in the wiring harness
O2 heater circuit wiring high resistance
O2 heater element resistance is high
Internal short or open in the heater element
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
Repair short or open or high resistance in wiring harness or harness connectors
DTC P0138 - O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
The Heated Oxygen Sensor (2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
A code P0138 may mean that one or more of the following has happened:
Faulty O2 sensor
Short to battery voltage in O2 sensor signal circuit
High fuel pressure (not as likely)
Here are some potential solutions:
Replace O2 sensor
Repair short to battery voltage in o2 sensor signal circuit.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Jul 06, 2012 | 1996 Jeep Grand Cherokee
Bank 1 lower oxygen sensor - replaced with mopar sensor check engine light still on
Hi Larry:
Faulty O2 sensor
Replace O2 sensor
Check it; hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 01, 2012 | Dodge Stratus Cars & Trucks
Oxygen sensor bank 01 code p138
Hi there:
Faulty O2 sensor
Replace O2 sensor
Mar 01, 2012 | 2004 Dodge Stratus
Hi there i have 1997 Avalon V6 . the check engine light up # 138 and 401 so can you tell me the name of that two please thnks
Trouble codes are normaly 4 digits with a "P" or "B" before it. I am gonna assume that you meant P0138 and P0401:
P0138 is Oxygen Sensor Circuit High Voltage (Bank 1, Sensor 2)
P0401 is Exhaust Gas Recirculation Flow Insufficient Detected
  • Faulty O2 sensor
  • Short to battery voltage in O2 sensor signal circuit
  • High fuel pressure (not as likely)
Possible Solutions Here are some potential solutions:
  • Replace O2 sensor
  • Repair short to battery voltage in o2 sensor signal circuit
for info on the P0401:
http://www.obd-codes.com/p0401
Jul 10, 2011 | 1997 Toyota Avalon
Engine code p0138
Symptoms: There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
Causes: A code P0138 may mean that one or more of the following has happened:
* Faulty O2 sensor
* Short to battery voltage in O2 sensor signal circuit
* High fuel pressure (not as likely)
* Replace O2 sensor
* Repair short to battery voltage in o2 sensor signal circuit
I hope this helps to solve it (remember to rate this answer).
Jan 09, 2011 | 1999 Jeep Grand Cherokee
What is nissan quest code p0138/p0139
P0138 - Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
P0139 - Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
The Heated Oxygen Sensor (1 or 2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
* Faulty O2 sensor
* Replace O2 sensor
Hope helps (remember to rate this answer).
Oct 11, 2010 | 2002 Nissan Quest
P0138 code
* Faulty O2 sensor
Possible Solutions: Here are some potential solutions:
* Replace O2 sensor
Hope helps (remember to rate and comment this).
Sep 15, 2010 | 2002 Jeep Grand Cherokee
O2 sensor code po138 is it something a handy but not car savy person replace?
  • Faulty O2 sensor
Possible Solutions, here are some potential solutions:
  • Replace O2 sensor
Hope help with this (remember comment and rates this).
Jul 22, 2010 | 2005 Chrysler Town & Country
P0138 02 circunit high voltage sensor 2 red light
FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebookcopyscape.gif Symptoms There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
Causes A code P0138 may mean that one or more of the following has happened:
  • Faulty O2 sensor
  • Replace O2 sensor
Dec 20, 2009 | 1993 Jeep Grand Cherokee
Metra Chrysler Interface Logo
74 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
