Question about Kenmore Refrigerators
Water pressure was low a couple of days now the ice maker won't work
  • 11,896 Answers
The lines may have frozen up.
Here is what you should do:1) Unplug the refrigerator.
2) Remove the ice bin and any loose ice from the icemaker.
GA_googleFillSlot("HT_Appliances_Refrigerators_Articles_Box_Top_Left_ATF_300x250");
GA_googleCreateDomIframe('google_ads_div_HT_Appliances_Refrigerators_Articles_Box_Top_Left_ATF_300x250' ,'HT_Appliances_Refrigerators_Articles_Box_Top_Left_ATF_300x250');
3) Find the fill tube, the white rubber-like hose that delivers the water into the icemaker.
4) Pull the small metal clip off the housing that holds the fill tube down (not all icemakers have this clip).
5) Warm the hose and surrounding mechanism. To do this, you can train a hair dryer on the icemaker to melt any ice blocking the mechanism.
Sop up dripping water with a rag. Be very careful when using the hair dryer near water, and do not stand in a puddle of water; there is a serious risk of electrical shock.
Also be careful not to melt the plastic parts. If you don't want to use a hair dryer, you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty icemaker bin. In some cases, it may be easier to remove the icemaker to thaw out the fill tube.
As a rule, refrigerators are the most dependable of all large appliances. Even so, they do fail to do their jobs adequately on occasion, and when they do, the results can be disastrous because expensive food can spoil in a hurry.
Though most problems call for a repair-person, there are a few simple repairs you can handle yourself by checking the power, controls, condenser coils, and other parts outside of your refrigerator's sealed, hermetic system.
Remember that the best way to lengthen the life of a refrigerator is to clean the condenser coils once a year—or more frequently if they get dirty.
Posted on Jul 31, 2009
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
My ice maker stopped working on my fridge. There is ice at the end of the tube feeding water to the ice maker. Could this be a faulty water valve?
yes or low pressure water pressure is what makes the valve shut so low pressure will let water leak past
May 07, 2008 | Refrigerators
Ice maker on G E refrigator
If you have low water pressure to the ice maker it can cause the unit to stick. If the water fill is ok then the ice maker is going out or the freezer is not staying cold enough. Icemaker has to reach about 12 degrees to cycle.
Apr 24, 2008 | Refrigerators
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
19 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
