Question about Konica Minolta Office Equipment & Supplies
Our magicolor 2490mf displays an error message that the cyan toner is not installed. We installed a brand new one and it did not help. Please advise. Thank you
I was having the same problem after a paper jam. As I rebooted, sometimes it would say Cyan and sometime Black. Here's the solution that worked for me. http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx Also, I noticed there was a little left to right play in the cartridge once it was in place. I pushed it (gently) to the left, too. All that fixed the problem for me.
Posted on May 20, 2010
Konica Minolta 2490mf . Have just put in compatible toner catrdges and printer is telling me YMCK toner incorrect can you help many thanks Steve
Perhaps clean the connections between the toner-chips and the printer.
As the are lokated below the toner cartridges in your printer the tend to get dirty
and cleaning them can make the difference...
If this does not help, try the old cartridges and see what message you get.
If that is a different one your cartridges doesn't match your printer and you should get replace ones.
Greetz, Robert.
Sep 06, 2011 | Konica Minolta magicolor 2490MF Laser...
Hello. Problem with my Konicia Minolta Magicolor 2400. Replaced the drum with a new OEM. Replaced the Cyan toner with a new OEM and the error message still flashes. The status screen says put in a new Cyan...
probably it's bad chip on cartridge or the chip was not reset.
Try with new toner cartridge. If its new go to the shop where you bought it and replace for new one under warranty.( If you are lucky and they give you a new one :-) ).
Hope that helps!
Apr 30, 2011 | Office Equipment & Supplies
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Change k toner error message
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
May 27, 2008 | Konica Minolta magicolor 2490MF Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
284 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
