Question about Bose Audio Players & Recorders
Cd player reads no disc when i try to play a cd
  • 2,237 Answers
The laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
Posted on Jul 31, 2009
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
Why does CD player read disc, then ejects?
It tries but can't read the disc, then it ejects it. If CD player plays other discs OK, then it is the disc. If it won't play anything there is a problem with the CD player.
Jan 12, 2016 | 2007 Fiat Bravo 1.4
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
American Audio Velocity CD Players Won't Play Discs
are your cd-r data or audio..(maybe AAV cant play the data disk) make sure its audio ...you can also try wiping the disk with a dry paper towel in a circular motion only (one way)...get any fingerprints /oils off the disk...
Jun 28, 2010 | American Audio Velocity MP3
Dvdcd player is not reading some cds and reads others
This has to do with the type of CD you are trying. Is it a VCD, SVCD, etc.? Also, some CD players will only play certain formats of CDs. For instance, it will play regular store-bought CDs, and will play CD-R discs that you have made in the computer, but won't play any RW discs like CD-RW or CD+RW discs. ALSO, some players will play CD-R and CD-RW but any + discs, like CD+RW are not compatible.
Basically all players will work with a CD-R, and usually CD-RW but the + ones are less compatible. If I knew your model CD player I could check for you, but that is probably the case. Stick with CD-R and you should be good to go.
Lastly, rarely, but sometimes, the drive may not like the disc brand you are using due to the composition used (like if the bottom is blue or greenish). Tends to be that blue or what they say is cyan discs work best. I use TDK and Verbatim branded CD-R and CD-RW, and they seem to work best.
Good luck!!
Apr 02, 2010 | Computers & Internet
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Aug 17, 2007 | Philips FW316C37 Shelf System
CD Player will not play all CD-R discs only ones it chooses. But if the CD is bought from a store it will play it.....if it is burned it usually will not.....even if the cd was just brned and plays on...
It might be an older system that can't read computer-made discs, or it could be a disc incapability. Most old players can't read CD-R discs, even if they can play normal/original CDs. You can try another media but i wont think it will help. Sorry.
Jan 04, 2006 | RCA RS2044 Shelf System
105 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
