Question about Kenmore Heating & Cooling
Kenmore model # 580.74055400
I have Kenmore model # 580.74055400 and am looking for replacement for the remote control as I do not know the part number for the remote control.
    Problem Solver:
  • 4 Answers
The part number is 6711A20089C for the remote control for this model.
Posted on Aug 01, 2009
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
Refridg nutZ
f54adfa5-965b-4b11-879a-627973789383.jpgKenmore has a model number like this example=> 321.12345678 Can you look around the fresh food section door frame for your model number? I need the model number so I know what to look for in the components that may cause this. A defective or bad connection at the pin plug leaving the door and
going to the control board is one possibility. A damp or corroded connection, loose pin plug on any circuit boards and even a defective thermistor. Let me know if possible, Thanks Sea Breeze
Jun 02, 2013 | Refrigerators
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
Aug 11, 2010 | RCA Universal Remote Control
Stopped making Ice cubes on S/S kenmore refrig. water nnot flowing in tube that runs up the back
This problem is the dual water control valve coil for that side. If you fill the ice maker with tap water and it cycles then the problem is most likely the dual water control valve on the rear and near the floor. Also make sure that the fill tube inside back of ice maker is not frozen over. Let me know the model number and I can tell you the part number for the replacement, Kenmore model numbers look like this for example 213.256489 Thanks, Sea Breeze
Aug 15, 2009 | Kenmore Refrigerators
Replacement Remote Control
email here--- parts@teac.com or you can try ebay.
Oct 24, 2008 | Televison & Video
Kenmore 790.91032404 I need a EOC
Go to searspartsdirect.com and type in your model number as you have listed. Look under the "Backguard" heading for item number 20 (part #316455420). Keep in mind, the EOC does not come with the overlay. That's the plastic cover that goes on the EOC that has all your controls printed on it. If your current overlay is still in good condition, it can be reused by carefully peeling it off the old EOC and reapplying it to the new one. If, however, you wish to replace it, look for item number 20A (part #316220711). I hope you find this information helpful. Let me know if you require additional assistance.
Oct 21, 2008 | Kenmore Kitchen Ranges
Lost codes
UMM IT WOULD BE HARD TO FIND ANOTHER ONE WITHOUT THE MODEL NUMBER THE BEST THING IS TO REPLACE IT @ 15.99 OR YOU CAN LOOK FOR SOMETHING SIMILAR ONLINE THAT LOOKS LIKE IT AND USING THAT MODEL NUMBER
DID YOU LOOK WHERE THE BATTERIES GO.
Oct 02, 2008 | Universal Remote Control Remote Control
Code
i am also looking for a code for this model number. if you know it could you please post it! thank you!
Jul 08, 2008 | Televison & Video
REMOTE CONTROL CODES
Maybe a good idea is to go find the original replacement remote control for your television. I know that the cost of buying a new replacement is almost the same cost as the universal remote and less hassle when you receive it, because the replacement will just work! I went to every tv remote controls website to buy the replacement remote control. They have a pretty large selection so hopefully they have what you are looking for. Great site with good customer service, I would definitely recommend them. If they don't have what you are looking for, there are other sites out there like them that can help, just search on google for your tv/remote model number and you should be able to find the original.
Nov 02, 2007 | Televison & Video
Heating & Cooling Logo
376 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
