This isn't a solution, it's backing that guy up, the Netopia modem he's talking about DOES need the driver or else it doesn't even recognized as hooked up through ethernet or USB both. The lights don't even flash red. So, unfortunately, the idiotic company decided it would be a good idea to make you need a driver for a DSL modem that should just be plug-and-play but isn't. In short terms, it seems, they just weren't thinking. Since I myself have lost my CD and am looking for the drivers, after going through troubleshoot, and all that fun junk myself, I know this as fact. ^_^ However, if someone could help out two guys who were entirely gipped on software that'd be nice.
Normally, routers, as separate devices, do not require installation of drivers.. Drivers allow hardware to 'talk' to software.. as a separate device, routers are installed in a network to allow routing across subnets.. Unless you are speaking of router software, like Vyatta, then I have to think that you need something other than drivers..
Perhaps you could illuminate the problem for us so we could suggest what you really need here?
Now, if you are just 'installing' a router, then we need to know the manufacturer and model.. If a consumer grade router, like Linksys, then it is pretty much plug and play. If Cisco, then it is a whole other matter, and you will need to get into the CLI to configure it.. This is not a simple matter, and not something that I could just write a solution for here....
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
my router is not registering the internet. the modem light is blinking yellow. My internet is...
(More)
my router is not registering the internet. the modem light is blinking yellow. My internet is working properly, if I plug it in directly to computer.
I seemed to have lost the speed when I set up the security, is that possible or is there some other...
(More)
I seemed to have lost the speed when I set up the security, is that possible or is there some other reason. The router is a Dx Nruter model.
I have a belkin g router ever since I started using it my computer freezes up and I have to hard...
(More)
I have a belkin g router ever since I started using it my computer freezes up and I have to hard boot
