Question about Hunter Ceiling Fan Light Remote Control
How do you set the switch for 3 adjacent ceiling fans
I just had 3 ceiling fans with the hunter remotes and when you use the remote the light goes on in one room and off in another
  • 10,865 Answers
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Posted on Jul 31, 2009
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'Azur® Ceiling Fan
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Jul 12, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter model 27576 (Canada) remote dropped
hi,
up above the fan near the ceiling theres a cover or canopy that has to come off , and theyre inside there, and they have to be set the same as the remote or it wont work.
good luck
J
Jul 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
532 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
