Question about Cobra Radio Communications
Need to turn down power output (watts) on cobra 29 nw wx st from 4 watts to 2 watts,can it be done through the pots?
    Habit-Forming:
    Scholar:
  • 69 Answers
Unfortunately, it's not quite that simple. There are several adjustments that need to be done to insure that you are not causing interference to others. Please take it to a tech and have it done right. Most people do not have the equipment required to do this properly. A good tech should be able to do it for you in less than 1/2 hour, and it'll be done properly.
Posted on Jan 12, 2019
One Wire
  • 126 Answers
SOURCE: meter and St lights
The backlit nightwatch lights can not be repaired, they are fiber optic lights that are ran through the faceplate by the factory.
As for the squealing, the normal way talkback is installed on these radios is to solder a resistor, 68 oms up to 100 ohms, from the PA to the External speaker on the solder side of the PC board. The more resistance, the lower the talkback volume. Yourse is probably squealing because the resistor is breaking down, I just fixed a radio 2 days ago with the same problem. If you want to remove talkback, just open the case, flip it tothe solder side, and remove that resistor that was installed, or you can replace it with a new resistor and still have talkback.
The meter is fairly easy to replace, you just need to get a new meter, make sure it is one for the Cobra 29 (it will have the 3rd line to show SWR reading, which the Cobra 25 does not). You remove the case screws, the face plate screws, and then remove one screw and loosen the other that hold the meter inplace. You will have to solder the two wires to the new meter, observing which post they came from, this will determine the direction the meter swings. You just remove the light bulb and put it in the new meter casing with the rubber stay. This will be self explanatory when you open the radio.
Now for the dead key. It may have had a swing mod done, which drops the dead key down a couple watts. This is actually a good thing. If you have a lower dead key, this will allow you a larger range of power to swing. You can tell if it has had a swing mod by looking at JP36 to see if there is a jumper or a Capacitor installed. If there is a capacitor, the it has been done. To change back to factory, remove the resistor that was soldered to the solder side, across the capacitor, then remove the capacitor. Now just install a jumper in the place. Here is a link to the Modification Instructions, so you can get a better understanding:
http://cbradiomagazine.com/March%202007/Cobra%2029%20LTD%20Super%20Modulation%20Modification.htm
If I left anything out, or you have more questions or need further clarification on anything, don't hesitate to email me rollincbmods@yahoo.com.
Dean PItts
Rollin CBs
Posted on Aug 31, 2008
venexcsd
  • 1185 Answers
SOURCE: can't find the audio IC number YD 1022
Click on the link below
http://www.a1telecom.com/shop/product_info.php?products_id=1286&osCsid=1b9c7585860f3a954210a1da964263e7
Posted on May 24, 2009
  • 212 Answers
SOURCE: radio powers up but no sound
Check E-Bay if not check here. http://www.khulsey.com/rv_info/rv_cb_radios.html Hope that helps.
  • 12 Answers
SOURCE: Cobra 29 NW WX BT Channel indicator
Still have the receipt? Take it back to the store and exchange it for another one. Easiest and quickest solution.
Otherwise, you can unplug the power from the radio and take the top cover off and check at the channel selector module to see if there's a broken wire or a broken solder joint. If the radio received rough treatment during some point in shipping (the outside packaging box may show no signs if it) it could be just a bad connection.
With the top cover off, replug the power and turn on the radio. BE CAREFUL IN HERE, THOUGH!! With a pair of insulated needle nose pliers, gently move the wires that connect to the channel selector module and see if it will light up. If so, disconnect the power and re-solder the joint or replace the broken wire. Reinstall the cover and reconnect the power, you should be good to go.
WARNING...if you open the cover on the radio, you cannot return it. Do this only as a last resort, if you can't return it for an even exchange for the same model radio.
Posted on Oct 25, 2009
  • 773 Answers
SOURCE: what exactly does the anl nb/anl button do on my
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Posted on Nov 24, 2010
Cobra 29 wx nw st how to increment modulation
Clip D-11 .diode 11 .this is the modulation limiter .
Jan 30, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
My cobra 29 wx nw st can recieve, but will not broadcast
Could be anything from a broken microphone wire to a bad final or regulator.
Sep 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I wish to tune and peak a cobra 25 ltd wx. please tell me what pots to turn. I have all of the necessary meters.
do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
Sep 06, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Echo on a cobra 29 nw
When you purchase an echo board, the instructions come with them.
If you need any help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 25, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Mar 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
48 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
