Question about Sony Ericsson K750i Cellular Phone
When people call there isn't any sound!!!!!!!!!!!!!!!!!!!!!!!
When people call ther isnt any sound.i tried reseting the rintone but it still doesnt work!!!!! can u help me?????
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
Automatic seatbelt doesnt work
if neither ther passenger or the driver seatbelt work it is a fuse. if not it is as simple as changing the door switch. if you dont see a visible door switch it is actually in the door and you should notice a door ajar light in the dash if the switch isn't working.
Apr 20, 2011 | Saturn S-Series Cars & Trucks
No power to motor is ther a relay
does it turn over and not start or no crank there is a relay but that isnt your problem if it turns over check fuel pressure at the schrader valve under the center engine cover (looks like a tire fill valve) if it doesnt turn over most likely cause bad starter or bad key
Apr 16, 2011 | 1999 BMW 328 Series
Only my touch screen isnt working, all the other buttons work, is ther ea rest that can do to fix this?
try resetting everything to factory default n restart ur 4n. M sure it was not dropped. Most touch screens end up this way because of shock.
Apr 09, 2011 | Samsung Cell Phones
Sound isnt working
Try to change the buzzer. But if your phone still have a warranty, just send back where you buy it. If it isn't the buzzer, you can try to reset to default setting.n It might also works.
May 11, 2010 | LG Dare VX9700 Cell Phone
I have to have the voume at 30 to get good sound
Try going into the menu and selecting the sound menu and resetting the sound to factory default..If this doesnt help matters you can change the sound preferences to custom settings..As long as the sound isnt distorted at low volume then this solution will apply..If the sound is distorted at low volume then your speakers may be faulty..sometimes caused by listening to the tv at full volume over long term which strains the speakers and prematurely ages them
Oct 17, 2009 | Samsung HP-T5044 50 in. Plasma TV
After deleting some files the sound doesnt work -no sound driver
Try "system restore" to a previous good working date, from>start>All programs>Accesories>SystemTools>System Restore
Apr 28, 2009 | Computers & Internet
Camera/ rintone memory
I hope you find this helpful, I work for a cell phone company called MetroPCS and I have access to the programming codes and such. You can try to perform a master reset on the phone. (note a master reset will cause you to lose all pictures and ring tones, however you will get to keep your contacts) The first thing to do is with the phone in standby mode press the menu button (left soft key) and the press the 9 key for settings followed by the 5 key for phone settings and the finally 4 for security. Next the "enter code" prompt should appear allowing you to enter the lock code, which is by default the last 4 digits of your telephone. If not that then try 1234. That screen will disappear then the security menu will appear allowing you to press 4 to do the master reset, you should then select yes with the left soft key. Hope you find that useful.
Aug 07, 2007 | Samsung SCH-a870 Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
