Question about Aiwa Audio Players & Recorders
Aiwa 6 ohms please what ohms of speakers should i used.
  • 10 Answers
SOURCE: 6 ohm speakers - 8 ohm amp
This is a tough one due to the info at hand, but I'll take a stab at it.
I'll assume that your amp is not a tube-type amp. I'll also assume it is a relatively recent "solid state" design. If those assumptions are correct, connecting a 6 ohm load to an 8 ohm amp should not cause significant overheating or amplifier instability.
Posted on Jan 04, 2008
easyq
  • 144 Answers
SOURCE: With my RX-V663 can I use presence speakers less than 8 ohms?
Basically you can use any speaker as long as you use the volume button wisely. Damage will only occur if you raise the volume level to the extremes. Bigger speakers should be no problem, if you want bi-amping, your speakers should support that as well.
Posted on Apr 17, 2009
bernardlunda
  • 318 Answers
SOURCE: can i use panasonic SB-AK57 speaker (6 ohm) with
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Posted on Apr 25, 2009
  • 454 Answers
SOURCE: Can I use 6 ohm speakers with 8 ohm system?
Probably OK, depends on the amplifier design. You have to be careful, especially at higher volume, the lower impedance will allow too much current to flow and burn up the amplifier.
Posted on Feb 06, 2010
  • 3 Answers
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
Posted on Feb 28, 2010
I have Speaker system aiwa SX-WNT9 Speakers 2 nos.Impedance 6 ohms/6 ohms.kindly tell me how me how much watt capacity amplifier is required for good sound.
Wattage is not the total solution to the problem. The amount of wattage an amp supplies is related to how loud you listen to the music AND how much power is left over so the amp can deliver when needed and not clip the available output signal and cause distortion.
Apr 07, 2017 | Audio Players & Recorders
I have aiwa nsx-kt9 speakers.kindly tell me how much watt amplifier will be right for these speakers
These speakers are 6 OHMS, that means you can only use an amp that is rated for 6 ohms. The original amp put out 20 watts (rms). Any amp rated above 25 watts per channel could do serious damage to the speakers if turned up to the highest levels.
Apr 07, 2017 | Aiwa Audio Players & Recorders
Can I replace the speakers on this system? Speakers are too large for space & want to replace with another brand.
make sure impedance is the same so 6 ohms and the power rating of speakers is no less than 200 watts peak rms.And bare wire ports on back of speaker.
The power rating is so the speakers can handle the maximum power delivered by stereo amplifier without burning out speakers coils.
Jan 23, 2016 | RCA Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
I have a aiwa cx nhmt75 home theater system which the surround sound rear speakers I believe model # sx-r275 for them has been misplaced or destroyed could you tell me what speakers can be used in place of...
You should be able to use any decent pair of speakers with an impedance between 8 Ohms and 16 Ohms and maximum power capability of at least 33 Watts. The link provided is for the specifications page of the owner's manual.
http://audio.manualsonline.com/manuals/mfg/aiwa/cxnhmt75.html?p=31
Aug 28, 2017 | Audio Players & Recorders
I am installing a MDS-6a system in my home Must I use all 8 ohm speaker thru up the house ? Can I use 6 ohm ,can I mix ? Thanks
That depends on the amp. If the amp is rated at 6 Ohm's you can, but it's best to stick to the same ohm speakers. If it is rated at 8 Ohm NEVER connect 6 Ohm speakers. The golden rule you can go higher but NEVER lower than the amps rated output. So if it says 6 to 8 ohms on the amp you can use the the 6 ohms speakers.
May 04, 2011 | Channel Plus MDS-6A Amplifier
Can I use 6 ohm speakers on my 8 ohm aiwa av-x300?
Hello
You can use 6Ohms speaker in place of an 8Ohms speaker. No damage will occur to the set, but the quality of sound output will be a little bit less and the output will be a little bit high. OK.
Mar 31, 2011 | Aiwa AV-X300
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
6 ohn wharfedale speakers on an 8 ohm TEAC amp (both old) - will that work
Yes. Most if not all speakers have impedances which vary with frequency and are rated at a nominal or average impedance. So a manufacturer who rates their speakers at 6 ohms may be more honest or chooses to quote it at a specific frequency. So a nominal 8 ohm speaker may actually measure 4 ohms at 100Hz and 12 ohms at 500Hz but averages somewhere nearer 8 ohms. It is normal for most speaker manufacturers to simplify their ratings so speakers which average at say 6 ohms would be categorised as 8 ohm, and 4.9 ohm averaged speakers as 4 ohms.
As a point of interest - some amplifiers are specified as providing their maximum power at impedances of 6 ohms, and there fore some speaker makers (including those made by same manufacurer as amplifier) will rate their speakers at 6 ohms so they appear more compatible.
Mar 05, 2010 | Audio Players & Recorders
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
37 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
