SOURCE: circuit board light blinks 3 times heater will not turn on
The error code refers to a defective combustion air switch. Coleman Evcons made around 2007 had defective pressure switches or as they call them "combustion air switch". Replace it and the problem is gone.
SOURCE: Where is the drain on the Aruba Majestic Hot tub?
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
SOURCE: I have a 2000 Sovereign Hot Spring hot tub that
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
SOURCE: OC hot tub is getting SL error and does not heat.
I have a Balboa spa that stays at 90 degrees and stays there. I try to increase the heat to 103 but it keeps staying at 90. there is a SL message on the control panle. What I can do...HELP ME!!!
SOURCE: need to know how to drain a warnock hersey hot tub
Only way to drain that spa is siphon out the water and then use a shop-vac to get the rest out, sorry that tub is kind of a pain.
Testimonial: "Excellent solution! That is what I indeed ended up doing- it's just like draining a waterbed. I used the shop vac to start the suction."
