There is a knocking on the left hand side foot rest is this a problem with the gear box
    Problem Solver:
  • 10 Answers
Souds like cooling fan needs to be replaced
Posted on Aug 10, 2009
The main fuse in jaquar
Hi Mohammed
what fuses are you wanting? for what item? if you require the location of all the fuse boxes they are as follows.
1, Under the hood ( bonnet)( if your car is left hand drive) it should be on the right hand side, if it is a right hand drive, it will be on the left hand side in a black box.
2, This will also depend on left or right hand drive, if left hand drive there is a fuse box either to the right or left in the foot well area where you put your feet it will be on the side it will be behind an panel .
3,there are 2 fuse boxes in the trunk ( boot) of the car as you look at the car from the rear they should be on the right hand side behind a panel
hope this helps
Jan 06, 2015 | 2008 Jaguar XJ6
Dose the foot brake switch also go DIRECTLY TO automatic gear box leaver to release it out of Parking mode?
no the sensor for that is down the side of the gear stick.should be the left hand side.may be loose.
Dec 18, 2013 | Cars & Trucks
When self starting there is weird noise from engine
You don't say what kind of noise. If its a whining type noise, check your starter, as they are very poor on the Baja's. If its a grating noise, then check the starting gear on the left hand side of the unit under the foot rest where the drive belt is located.
Oct 29, 2013 | Bajaj Motorcycles
Kawasaki EL250 Eliminator 1987 model will only go into first gear and Neutral no others
All kawasakis will only go into first gear or neutral until you are doing approx 12 mph...
May 31, 2012 | Motorcycles
How do I change on my Buell M2 cyclone?
First be sitting on the bike, what you will need do do is hold onto the handel bars and start the beast, let it warm for a minut or two.
Once you have done this you are almost redy to change :-)
Ok heres here it get interesting, youll need to rest you left foot on the left foot peg what ever you do don't get confused and put the wrong foot on the wrong foot peg or somthing really bad might happen when you make the change!!.
Ok assuming that you've done that youll need to pull the clutch in, once youve done that gentley but firmley stomp on the gear leaver (Its the one on the lefthand side of the bike just infront of the left hand foot peg)
OK, you've now made the first change!!!! from here youll want to gentley release that clutch, once you feel the BUELL start to move your gonna wanna give it a handfull of throttle whilst ajusting your left foot to be directley underneath the BUELL, once you foot is inline quickley grab that clutch in again and lift you foot thats underneath gear leaver, rince and repeat :-)
Jul 27, 2010 | 2000 Buell M2 Cyclone
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
I have broken my foot rest on the left side for my Help please!
send me a picture olliecompressor@hotmail.com t depends where it has broken buddy
Oct 22, 2009 | 2000 Aprilia RS 125
Need to find all fuse box locations. Multiple exist, but can't find other than one by battery
there is another fuse box on the driver side next to the foot rest ( left side )
Jul 08, 2009 | 1991 Toyota Camry
How to drive a motorbike?
you should have a cbt test but you pull the right throttel back lightly when you start it up. pull in the clutch on the left handel bar its the brake.keep it pulled in untill you select agear relase the brakes and slowly role away. on the right hand side is gears near the footgears go one up 2 down. it might be on the left. near foot rest. be carefull its not easy. if you rev to much you go flying off keep the brakes on.
Mar 26, 2009 | 1975 Ducati 350 Scrambler
Rav4 gear problem
You need a new 5th gear- luckily this is easy to replace- I did it myself following online directions for 5th gear replacement. The 5th gear is not in the box with the other gears- its off to the side so you can access it very easily by removing the left front wheel. Just don't let the idler assembly come apart, lots of tiny parts and springs...
The 5th gear can ware out prematurely if you rest your hand on the shifter- do not rest your hand on the shifter in the future.
Nov 08, 2008 | 2004 Toyota RAV4
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
