I have a imperssora Epson XP-520 which now does not work, displays in the display code 0x05 error. What to do.
2 Related Answers
hichbiri
Huseyin Huseyin
  • 3469 Answers
  • Posted on Jul 19, 2015
SOURCE: 0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
303electroni
303 Electronics
  • 370 Answers
  • Posted on Aug 21, 2019
Try this fix in the video. It may be something very simple. After you resolve issue, make sure to turn printer off and then on again to clear error.
HOW CAN I FIX WF7620 ERROR CODE 0X88 PLS
http://printcopy.info/index.php?l=en&mod=erc&brand=Epson&model=WorkForce%20WF7620&code=0x88
Diagnose and replace parts if necessary, quoting from link above:
Epson WorkForce WF7620 Error Codes All codes 0x01 0x02 0x03 0x04 0x05 0X06 0x09 0x0A 0x0B 0x0D 0x0E 0x10 0x11 0x12 0x13 0x14 0x20 0x30 0x36 0x41 0x42 0x43 0x44 0x45 0x46 0x49 0x4A 0x4B 0x4D 0x4E 0x51 ... 0x55 0x60 0x63 0x67 0x68 0x69 0x6B 0x7F 0x81 0x82 0x83 0x84 0x85 0x86 0x87 0x88 0x89 0x8D 0x8E 0x8F 0x93 0x97 0x9A 0x9B 0x9C 0x9D 0x9E 0x9F 0xB0 ... 0xCF 0xD1 0xD2 0xD3 0xD4 0xD6 0xD8 0xD9 0xDA 0xDE 0xDF 0xE1 0xE2 0xE3 0xE4 0xE5 0xE8 0xE9 0xEA 0xEB 0xEC 0xEE 0xEF 0xF1 0xF2 0xF3 0xF4 0xF6 0xF8 0xF9 0xFA 0xFE 0xFF
Code
0x88
Description
Printer. PIS Excessive Light error
Causes
• PIS failure • Main Board failure • Diffused light
1helpful
2answers
2answers
Nokia lumia 520 unlock pin required
Hello. To which network has your Nokia Lumia 520 been locked to.? You can get the unique unlock code for a Nokia Lumia 520 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia Lumia 520 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 520.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 520 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 520 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 520
SOURCE: MobileUnlockGuide.com
Nov 11, 2014 • Cell Phones
HOW DO I FIX ERROR 0X05
that an internet explorer problem try this (http://www.solvusoft.com/en/errors/runtime-errors/microsoft-corporation/internet-explorer/0x05-internet-explorer-8-error-code-0x05/
Communication error epson 520
Check your cables are in the correct positions., Turn the printer off and reboot your computer. Check the computer and see if it " finds" the printer. On the PC, press "start" look for and click on "printers and or accessories" Your printer should be displayed there. Click on properties. If the PC cant find it, I would say the cable is damaged or disconnected or the software for your printer has been deleted or failed. You may have to reinstall the software again.
How to get unlock code for nokia lumia 520,imei :351737060551944
Hi. You can get the accurate unlock code for your network locked Nokia Lumia 520 either from the respective network provider or from trusted online vendors like MobileUnlockSolutions.com at affordable cost.
4helpful
How to unlock a phone. Nokia lumia 520
Hi. You can unlock a Nokia Lumia 520 safer and easier using unlock code. You can get the accurate unlock code for your Nokia Lumia 520 either from your respective network provider or from any trusted vendor online like TheUnlockArena.com at affordable cost.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
