Question about Danby DKC645BLS Compact Beverage Cooler
Actually have the DAR604BLS - Danby Silhouette - looks like the plain fridge version of above pictured beverage fridge. Electronic digital display on front. Unit stopped running. Display reads interior temp of 73 degrees, controls allow the temp to be turned down but the fridge does not start up. Makes absolutely no noises or any sound that makes it look like the compressor is even trying to start. The unit is only 9 months old, but they won't cover any of the 24 month warranty because I did a mod to the fridge by mounting a beer tower through the top. The tower goes no where near any electronic or cooling components. Unit functioned with tower for the 9 months so far.
SOURCE: Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Posted on Aug 20, 2007
  • 619 Answers
SOURCE: new danby kegerator - tastes like rubber hose
you may report the problem of taste of beer the store where bought it , byu the when it new smell strange but it better clean in second time by flushing of water before you attache the beer tank, for the time the fume of rubber connection still inside on that machine , (in purified water need to back wash in order to make a purified water good taste and clean, ) the term use of that machine is "flushing " .
Posted on Jan 01, 2008
SOURCE: how to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Posted on Jul 06, 2008
  • 27 Answers
SOURCE: danby freezes all beverages
check position of thermistat bulb it should be on the plate
Posted on Jul 29, 2009
  • 43501 Answers
SOURCE: my danby beverage centre does not cool anymore 3
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Posted on Oct 08, 2010
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
How do I turn off the danby silhouette
There may be an on-off switch or if not, pull the plug.
Nov 29, 2014 | Danby DBC514BLS Silhouette Beverage Centre
We just received our Danby 35 bottle wine fridge with digital temperature display, and cannot turn off the light.
I found the users manual for your Danby! You have erroneously called it a 35 bottle unit, when in fact it is a 50 bottle unit. Click HERE for you manual. In the manual, it says you can use the light manually or automatically. There appears to be a switch on the bottom of the unit. I suggest the manufacturers manual for it holds a great deal of information that can be of assistance in the future, as this is a discontinued model
Good Luck, and I hope this is the answer you are seeking. Please rate and comment, Thank You Joe
Sep 07, 2011 | Danby Silhouette DWC512BL Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
I have a danby dcr412 fridge the compressor comes on but it doesnt get cold
you may have a gas leak or you need to get new gas in it or it could be the thermostat. prety much if the compressor is running but it doesnt get cold these are the two most obvious things to check. hope that helps, let me know how you go.
Feb 04, 2011 | Danby (DAR604BLS) Refrigerator
Freezer freezes, fridge not cold, smells very exhaust like
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Jul 20, 2010 | Danby (DAR604BLS) Refrigerator
Danby freezes all beverages
Jul 26, 2009 | Danby DAR259BL 2.6CF Silhouette Compact...
Danby DKC645BLS Compact Beverage Cooler Logo
71 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
