Question about Linksys Wireless-G WRT54G Router
All the lights or on.On my router.But I cant it on
All the lights or on.On my router.But I cant get on the internet threw it.I have my computer hooked up just threw the modem and it works fine.
  • 3 Answers
A couple times a year I have to reset my WRT54G back to the factory defaults. There are a couple of methods to do this.
Reset Button Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
All the lights or on.On my router.But I cant it on - linksys-reset.png To reset your router, use the following steps:
  1. Press the reset button for 30 seconds. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  2. Open up your Web browser and enter “192.168.1.1? in the address bar.
  3. For the login, leave a blank ID and enter “admin” as the password.
The router has now been reset. You'll need to go back in and set up any passwords or wireless security you had set up before.
Through the Web Administration Pages The second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1?.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page.
The router should now be reset to the factory defaults. Again, you'll need to go back in and set up any passwords or wireless security you had set up before.
Posted on Aug 07, 2009
The internet is not working
Make sure you hook you tv up with your home network threw Wifi. on the tv menu look for a network menu, it would than ask you if you want a wireless connection , than it would find your network from home. Also if that doesn't work try getting a better router ( dual ban router would be best) Thanks JC
Nov 07, 2013 | Vizio M550NV 55 in LCD HDTV
Can't get to internet. says i'm hooked to internet but cant go any where.
Check the lights on your modem and make sure that it is connecting. If it is, power off the modem (unplug it normaly) and the router (same unplug). Now wait a few mins, power the modem back on first and wait for all the lights to turn green (some cable modem will have a yellow light). Now plug in the router and wait for all its lights to come on. Now try the internet again. If this fails disconnect the router from the modem (ethernet cable) and plug your computer directly into it. Restart the modem as you did before and when all the lights are on, try internet again. If you have internet at this point the problem is in the router somwere, if not call your internet service provider.
Jul 21, 2011 | Computers & Internet
Internet Explorer cant bring up web page when the wireless router is hooked up. It will when the computer is hooked up directly. The computer says that is connected to the wireless router but IE still cant...
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | NetGear RangeMax WPN824 Router
Cannot find DNS address
well make sure that your computer isnt restricting the xbox threw ur router. if it is then it should pop up when you try to connect and just say unblock!
if not try hooking up just the modem{no router] to the xbox.. if you can go on the internet threw the computer then the modem should let the xbox threw.
if not then try turning off both the modem and router so then reset.. pull the power cords and wait 25 secs
Jun 24, 2009 | Microsoft Xbox Console
Computer can't find the router
Configure your router first, by doing that you need a ethernet cable (cat 5 will do). Connect your computer to your router using ethernet cable and open internet explorer, type in the ip address of your router and press enter. After that, you will be ask for username and password, just key in your username and password (if you cant remember, reset your router and key in the default username and password of your router). Once your done, go to internet setup and you can configure everything there. Hope it helps you.
Jun 21, 2009 | Dell Wireless 2350 Router
Router isnt working
Check the network connection physically, if your connected properly then nothing happened? check the lights of the router? if the link lights of the router is not lit you needing to get an another router.
Mar 25, 2009 | Computers & Internet
No internet connection threw Dynex DX-E402
  1. Go to Control Panel on your computer. Then Click on Network Connections. Look for Local Area connection. RIght click on it and click properties.
  2. Look for Internet protocol TCP/IP. Select it and click Properties. Make sure that Obtain IP address automatically and Obtain DNS servers automatically.
  3. Then, check the IP address of your computer by doing a right click on Local area connection again, but this time click on Status then click support. The IP address that your computer should have is in the range of 192.168.1.x
  4. You may also check if the Ethernet light on your router is on for your computer's connection.
Hope this helps!
Nov 15, 2008 | Dynex 4-Port Ethernet Broadband Router...
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Linksys Wireless-G WRT54G Router Logo
372 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
