Fedders A7DH65B2A Dehumidifier
Problem for Fedders A7DH65B2A Dehumidifier
Fan not working
By medicinmanty on Jul 31, 2009
fan motor seems to have quite working. Definatly see a pattern here.
Solution #1
posted on Aug 25, 2009
Not Rated)
blvl777
Rank: Guru
Rating: 88%, 91 votes
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Was this helpful?
Yes
No
Popular Solutions for Fedders A7DH65B2A Dehumidifier
Questions and Unsolved Problems for Fedders A7DH65B2A Dehumidifier
Do you recommend Fedders A7DH65B2A Dehumidifier?
Answer
Answer
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!... (More)
Answer
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the... (More)
Answer
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no... (More)
Answer
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fedders A7DH65B2A Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
