Question about Hoover Elite Rewind Bagless Upright VacuumVacuum
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
I have a Hoover Mach 3 cyclonic vacuum (my understanding is that the name was later changed to Hoover Fusion). I'm having issues with the dirt not reaching the dirt cup. The dirt will stay trapped in the hoses, causing the unit to overheat. Every time I vacuum I have to clean out the hoses because the dirt gets stuck right at the entry hole for the dirt cup! Any suggestions? Thanks!
    Problem Solver:
There is a filter in the top over where the dirt canister clips in, and one under the dirt cannister by the motor. Sometimes removing and cleaning will help if you have not tried it already.
Posted on Dec 27, 2014
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Posted on Sep 02, 2009
Dirt cup release button is stuck and not operating even after pressing very hard. i am worried it will brake. Please guide.
Hello there! The dirt cup bottom door should swing open quite easily when the release button is pressed. If you are concerned that you may break the dirt cup we recommend you take your vacuum to a Hoover authorized service center for assistance. The UH70015 comes with a 60 month limited warranty. Follow the link below to locate the nearest service center to you. Service Center Locator
Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Just bought this Hoover Fusion vaccum used, cleaned it up, checked belt and filter, turned it on and is extremely loud, almost like a scream. Any idea what could be causing this and how to fix?
Loud noises from this model are caused by dirt build up on the suction fan mounted directly to the motor. Under the dirt cup there is a filter screen that should have a foam filter insert, when not used or cleaned properly allows dirt to get into the motor. Cleaning is the best option. Although if you are inclined, you can take it apart or take it to your local deaLer.
May 01, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Is my model nno. US183900 S/N 080600079068 still under warranty? I have a broken hinge post in the bottom cover of the dirt canister. Thank you.
The Hoover Fusion Plus Cyclonic Upright Vacuum has a 1 year manufacturers warranty from date of purchase. You need to check your reciept to see if it's under a year old. Then go to the Hoover.com web site to find the closest Hoover warranty service center to where you live. Bring the proof of purchase and the vacuum to them.
Apr 08, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Cannot remove dirt cup for emptying
It has a release button some where , you need to find it...(my wife had same issue...i left her to find it :)..
hope it helps...keep the hope :)
May 19, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover Elite Rewind Bagless Upright VacuumVacuum Logo
419 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
