Question about HP PSC 2175 All-In-One InkJet Printer
Printer wont go on
I used printer and when I wanted to make another copy it said I was low in paper. I added more and it said paper was too narrow. I have always used the same paper . I adjusted the tabs and tried again would not print. I shut off printer and when I tried later on it would not turn on at all. I removed the power cord from the powerstrip and put it into a 3 prong wall still does not turn on.
U kindly plz adjust your printer. again or else if u still hav the problem check whether is ur printer is read by u r computer check it on printers and faxes. try intalling ur drivers again
Posted on Nov 25, 2007
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
I continue to receive "paper too narrow. load with wider paper" message despite using 8 1/2 x 11" paper. This was not an issue I've ever had before and am using the same size (standard) paper as I always...
Check the Paper Size Settings.
The only document I found at that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
If you have a problem just reply on us.
If i am helpful please rate me.
Thank you.
Aug 24, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
Printer shoots out blank paper
Hello. More than likely, there is an issue with the paper feeder itself. My HP printer did the same thing, and HP took care of the problem for me. If you call the manufacturer, you should be able to send it to them and they can fix that issue. If you have any questions, please contact me at
Mar 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
My HP 2210 all-in-one is not printing or taking commands from my windows FX. When I try to copy it tells me the (normal)paper is too narrow. Help!!!!
Try to load more paper in the paper loader. you have to put at least 75% of the paper capacity it can hold. The printer cant grasp the loaded paper coz its too narrow.
Nov 28, 2008 | Office Equipment & Supplies
Hp fax/scanner # 6110
Hi Judy,
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell 1600n: Toner marks down the center of the page.
There are 2 seperate glass areas on the top, the large one is for when you lift the cover to scan or copy, the little narrow one is when you use the ADF. If there is a dot or a spec on the narrow part, it will leave the streak on the page, Clean the narrow part really well. I use a foaming window cleaner, and a razor blade.
You may also want to check to see if there are any small scratches on that glass. That will cause the same thing to happen.
Nov 14, 2007 | Dell 1600n All-In-One Laser Printer
Lines through copies
The scan glass is dirty or it has a scratch on it. It can be a small dot of ball point pen ink. A small ball of tape adhesive. A is not always easy to see. Clean it with a good solvent.
Also if the ADF feeder tray is out of adjustment, it could be caused by the edge of the paper.
Nov 01, 2007 | Office Equipment & Supplies
HP PSC 2175 All-In-One InkJet Printer Logo
Ben Johnson
