YAMAHA RX-V1070/970 The dial light has burned out. How do I get to the light to change it? rcohn@centurytel.net
  • rbrtchn Jul 31, 2009
    OK..........Now the cover is off and I can see where the bulb has to be located, but how do I get to the bulb which is inside a white housing connected to a circuit board with no obvious screws or openings.
    Robert Cohn
  • 19,396 Answers
You remove the outer enclosure, undoing all screws mainly located in the back panel, and get straight to the back of the front panel, where you see the lights.
To do things properly, get the service manual, with detailed pictures: RX-V1070/RX-V870
Posted on Jul 31, 2009
    Brigadier General:
  • 3,614 Answers
In able to access and change it your have to remove the cover of the unit. Remove the part that has to be replace and get the part # in which you will need to order for a new replacement.
Hope this helps
My new receiver rx a3020 smell like burning
do u have warranty ? RUN to where u bought it
recommend u to not use it until some expert don`t look inside , for now u dont nave problems except smell but that can change very very soon and then repair can be way to much costly
Jan 18, 2013 | Yamaha RX-A3020 RX-A3020 Home Theater...
Yamaha RX-V671receiver does not power on,
you should open the reciver, let it dry and with a thoothbrush clean the circuits.
it could help, but if anyrthing electric is burn inside you need to change it.
Sep 11, 2012 | Yamaha RX-V671
Light does not come out on the lcd of the rx-360
Pilot light burned out and has to be replaced. 14.5V 115mA lamp part number VA739600.
Nov 17, 2009 | Audio Players & Recorders
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
Yamaha rv1000
ok yu problem has to be with the protection system before you burn it up it collapses to protect the whole system.....go direc to the thermal cut off devices on the main output and then to the power system......
Dec 27, 2007 | Yamaha RX-V1000 Receiver
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
141 people viewed this question
 Grubhead
Grubhead
