Washer worked yesterday only when I ran the dryer. Now the washer is full of water and it won't start again.
  • 4 more comments
  • lucky_child1 Jul 31, 2009
    Hi Shereena,
    My washer is a stacked kenmore. The previous owners seemed to have ripped off the make and model #. It is not new enough to have a screen to display an error code. I have just unplugged it, will wait 10 minutes.
    It's still not working.
    any more ideas? we're going away for the weekend and i'd rather not have the washer full of water.
    thanks,
    luckychild
    Hi Shereena,
    I'm not satisfied with my service on this website. Please inform me on how to reject a solution and receive a refund please.
  • lucky_child1 Aug 03, 2009
    Thank you very much for your response! We just got back from vacation so we're going to wait until tomorrow to try out your solution. We're happy with your feedback and we'll let you know how it goes!
    HI,
    We tried your solution and it worked as well as I think that it could! Thank you very much for your help!
  • Washing Mach... Master
  • 2,200 Answers
Your machine is locked up and will not start until you drain the water from the machine. There can be various causes as to why the machine is not draining. The main causes of this are blockages or pump failure.
You will need to pull the machine from the wall and using a bucket or suitable container remove the outlet pipe from the standpipe and allow the water to drain fully from the machine. Whilst you are there check that the drain pipe from the machine is
1) Not blocked/obstructed or pinched in any way (if connected to a sink U bend this is a troublespot for blockages so be sure to check this)
2) Check outlet pipe is free standing in the standpipe. (Check domestic drain is not backed up if this is the drainage method)
3) Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front of the machine. You can unscrew a plug from this and check the filter for blockages.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines for example have a filter inside the sump hose which gets blocked.
Finally, if there is no evidence of blockage anywhere after these checks the pump itself can be faulty and if this is the case it will need to be replaced.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Aug 01, 2009
  • Radio Code Pro
    Radio Code Pro Aug 03, 2009
    Hey - thats great and do let me know how you get on.
    Don't forget to accept my answer if you get a resolution - otherwise it goes to the previous expert. If you still have problems just post another comment for my attention.
    Many Thanks
    RixesFixes.
  • 601 Answers
Hi...
Do you get any error code?
Unplug from the wall and retry after 10 min.
Also let me know the make and the model no#.
Thanks
Smith
Posted on Jul 31, 2009
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
I ran my mower out of gas and I know I had some water in the tank. I filled it wirh gas and 350 ml of isopropyl yesterday and it still won't start today. It fired up twice yesterday but stopped right...
Your condition sounds like a particle may be plugging the carb. IF you have good fuel flow to the carb, then take the carb apart and blow out any passageways. While there, drain all fuel and put in new fuel.
May 28, 2011 | Briggs & Stratton Garden
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
Washer stopped working with clothes and water in it
If you try to wash too many items with the water level set to low it is hard on the drive sysem and will kick out the motor.
When the motor resets it should work again but its very bad for the motor so II would try not to do it again.
Good Luck
Quentin
Jun 04, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Maytag atlantis washer making loud grinding noise
The belt are tear and slap to the near obtacle need to replace /
The water magnetic valve are leaking ned to replace /the coil open or valve rusted.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
